Hi all,
I’m trying to work out the best way to modify my vox ac15hw1x so I can use an attenuator.
The internal cable that connects the speaker to the amp is not terminated with a jack plug (I believe), it is hardwired instead. So I need to do a mod so that the attenuator can be connected to the internal speaker.
I am not an expert with these things but here is my plan:
1. Purchse two new 1/4 inch mono jack inputs (similar to the type you get on a guitar) and fix them to the back wood cover of the amp.
2. Disconnect the cable (from the spade connectors on the speaker) and attach it to the spades of the first of the new jack inputs.
3. Create a new cable with 2 female spade connectors on both ends and attach one end to the speaker spades and the other end to the spades of the second of the new jack inputs.
Then for normal use of the amp without the attenuator i’d need to run a short patch cable between the new input jacks.
And when using the attenuator - i’d need to run a guitar cable from the speaker out socket on the attenuator to the second of the new jack inputs.
Is my plan the best way to achieve what I’m trying to achieve? I can’t be the first to try to solve this problem. Is there an easier way?
If the plan is sound can anyone tell me if there is a kit for it so I don’t need to buy all the individual bits and pieces?
Neutrik NMJ4HC-S 1/4" Mono Phone Jack Switched
For the switching, you can either do it so the first jack switch breaks the path, and the second jack is simply connected to the speaker, or if you want better reliability (and safety, for the amp) you can cross-wire the jacks so *both* switches need to be open before the path is broken. This is easy to do if the jacks are fitted with the terminals facing each other.
Looking at this pic, it looks like the jacks are about the right distance apart to mount like that with short jumper wires between the terminals. They may even both be switched jacks as stock - at least one of them must be if it turns off the internal speaker. If so, you only need to rewire them.
can this be done?
So you connect the external cab jack - which disconnects the speaker - to the input of the attenuator, and the output of the attenuator to the extension cab jack, ie back to the speaker.
