Anyone used tape around string ferrules?
lovestrat74lovestrat74 Frets: 2489
edited May 2019 in Making & Modding
I have vintage tuners but the ferrules are too small so I was wondering if anyone had success with tpfe or electrical tape etc to get them to fit?
The ferrules that came on the neck ( no tuners just ferrules) I am trying fit tuners to are too bulky and my kluson style posts wont fit through..
I know I can buy some but these tuners are aged and it would be hard to match the up
  • munckeemunckee Frets: 12254
    Is it for Tele/Strat - I've got a couple of sets of aged ferrules I think of different thicknesses, you want me to post them to you to try?
  • lovestrat74lovestrat74 Frets: 2489
    Nice one Adam - community spirit :+1: +1:
  • ICBMICBM Frets: 71952
    I use masking tape, both on tuner ferrules and the ones on the back of Telecasters, if they’re not tight enough to stay in by themselves. But only if they’re very close to a good fit. If they’re much too loose you just need ferrules that fit better.
    :+1:
  • gavin_axecastergavin_axecaster Frets: 526
    Tape works ok for string-through ferrules as the string tension pulls them into the hole. However for peghead bushes tape can compress too much and the bushes may move so (assuming you can't find tuner bushes the correct size) cut up an aluminium drink can to make sleeves. That will give a firm fit with little chance of compressing/working loose.
    Wow never heard that before! Or... click the link and buy some ones that actually fit  =)  Think there will be a little order coming your way soon :+1:
    It's actually an old roadside-mechanic fix for worn parts or ones that just don't fit tightly enough :). It works very well, in fact.
