Secret Delay setting
  • Dan_HalenDan_Halen Frets: 1646
    Jalapeno said:
    Ok, I'll ask ... WTF is a DUCKED DELAY ? ;)
    Makes for a quacking lead sound
  • FunkfingersFunkfingers Frets: 14321
    … especially if you add a Peking filter.
    Be seeing you.
  • Really crisp but plummy texture.
  • RandallFlaggRandallFlagg Frets: 13929
    one that doesn't work...oh no, wait, hang on you said ducked.
    A ducked delay means that while you're still playing, the delayed sound is quieter to avoid it getting messy but when you stop playing the volume of the delay comes back up so you can hear the trail left more clearly.
  • 90ms 1 repeat for slap
    150ms 1 repeat stereo for Van Halen/rock bigness
    168ms 3 repeats for some blues rock reverb
    350 4 repeats for full on rock soloing
    1/4 into dotted 8th loads of repeats for some fun
  • kennedydream1980kennedydream1980 Frets: 1143
    edited May 2019
    I use a dual delay on my AX8, left side set to 350ms, the right side set to 500ms. I have it running in Parallel rather than series so it stays out of the way of the dry guitar tone. About 3 audible repeats on each side. Mix set to 100% as it’s in Parallel, level at about -10db
  • JalapenoJalapeno Frets: 6378
    Feedback
  • grungebobgrungebob Frets: 3299
    I find the best setting is off.
  • p90foolp90fool Frets: 31367
    Just use tap tempo, then you can show off your skills to the audience of playing, singing and standing on one leg while bouncing the other one up and down on every button except the one you want, all with your tongue sticking out the side of your mouth like a toddler learning to use scissors.
  • HalikusHalikus Frets: 59
    The key is 100% having a ducking delay as per Dominics post, no ducking and its just a mess.
  • builttospillbuilttospill Frets: 456
    Current fav setting, shortish delay going into dirt, getting some lovely tones especially with the warthog
  • PolarityManPolarityMan Frets: 7273
    Thing with  ot using tap tempo is that it's a total ass to try and make your drummer in time to your repeats.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • joetelejoetele Frets: 947
    The Digitech Hardwire DL-8 I acquired recently from a fine chap on here has a 'secret' setting - not sure if it's just how the pedal works or some issue, but the third delay on the selection knob, when set completely to the shortest time, does a lovely glitchy delay that £300 boutique pedals normally give you. So effectively it's saved me buying at least one of those.
    MUSIC: Pale Blurs
  • vizviz Frets: 10643
    And mallard valves
  • ChuckManualChuckManual Frets: 692
    Analogue delay; 90ms, single repeat, 40% mix, to thicken. (nearly always on)
    Plus, when needed...
    Digital reverse delay; 300ms, two repeats, 30% mix, to lift.
    Analogue delay; maximum triplet value available, repeats skating on the edge of self-oscillation, 50% mix, to visit Mars.
    Not much of the gear, even less idea.
  • VaiaiVaiai Frets: 530
    edited June 2019
    I set mine to the click of the sticks at the start of the song... then re-tap it just before the solo as it is inevitably a much different tempo
    Gassage said:
    480 into 720. Lush as fuck.
    What type of delay - analog ; tape etc ? Any modulation? Hipass ?
  • I use a dual delay on my AX8, left side set to 350ms, the right side set to 500ms. I have it running in Parallel rather than series so it stays out of the way of the dry guitar tone. About 3 audible repeats on each side. Mix set to 100% as it’s in Parallel, level at about -10db
    I now use the 2290 delay in stereo on the AX8 set to 500ms running in series, and I prefer it to my previous settings above ^^
