I'd wire hot and earth directly to the output jack, then take a wire from each side of the output jack to the switch, such that the switch connects hot to earth to short out the pickup when engaged (i.e. treat the DPDT switch as a simple make/break SPST switch.)
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
Bandcamp
Bandcamp
As I always have to say, make the green wire an 'x' between the lower four terminals rather than a 'u' between the bottom two for better reliability.
Bandcamp
If you have a DPDT, just wire both poles in parallel since that will also improve reliability.
Bandcamp
Bandcamp
2 5
3 6
1 and 4 to standard electrics
2 and 5 to jack
3 and 6 to backup pickup
Bandcamp
I give up!
Bandcamp
Bandcamp
Bandcamp
OK, maybe you're misunderstanding. You don't need to switch the ground connections at all, they all remain connected all the time. The only switching you need is on the hot connections to the jack, backup pickup and output of the standard electrics.
Bandcamp
