I'm pretty sure the Blackstar doesn't have an earthed power supply, it's a low-voltage DC one, so that probably won't help either - although, if you can run the headphone output of the Fly (which is also speaker-emulated) directly to the line input of the desk *not* via the DI box - you'll need a 3.5mm to 1/4" cable for that - it may work.
