Here we have a tremolo that mounts normally but converts to a narrower Gibson like spacing to help where a narrow neck means the strings are prone to slipping off the edge of the neck.
The front mounting holes will fit your vintage strat body with no problems or issues at all, but the block and the saddles are geared up for a narrower string spacing (10.5mm between centres rather than the older 11.2mm), resulting in an E to E spacing of 52.5mm and bringing those E strings in from the edges of the board.
We called it the "double whammy" because we use the fabulous Highwood saddles that have no sharp grub screws protruding through the plate on this tremolo. The rest of the trem is made of the same original materials that Fender used in 1954 too so sonically the same - cold rolled steel block and CR4 steel for the other parts. Even our nickel plated springs are accurate in size and tension to the Fender originals.
The new family of FatCat Big Blocks for Floyd Rose tremolos (both Floyd Rose and Schaller brands and any others that have the same screw mounting).
Using cold rolled steel gives back a lot of lost frequencies that a Floyd Rose typically loses for a more balanced overall sound. You get bass back but there is tight definition in the bass frequencies and the high end is firm but not shrill.
We can also offer brass blocks but the cold rolled steel seems to be more even in frequencies rather than just fattening the sound.
Compare the width of the original brass block and the fatCat Cold Rolled Steel Big Block. Easy to fit and reassemble and available in various heights to suit your guitar.
We will also be offering blocks for the Jackson JT6 tremolo that featured on many late 80s Charvel and Jackson guitars, as well as a few possible Ibanez options too.
We also sell replacement blocks for your existing tremolo and other parts too
These are all made in UK to the same vintage specs as the 1950s Fender ones
Cold rolled steel for the blocks, CR4 sheet steel for the claws and spring steel for the springs
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
(formerly customkits)
Blocks to fit Edge, Hard Rocker and Pro Rock'r would be most welcome.
If you want to make a killing, manufacture those cast "Tee" pieces where the Pro Rock'r intonation and saddle lock down screws meet.
I am half serious . It's a real problem when the originals fall apart, they're one of the hardest things to replace unless you're incredibly lucky and find a second hand one that's still intact.
Although I'm well aware that it would be about the same price as the value of the guitar...
We all know that the design is atrocious but it may be the only bridge that fits some guitars without resorting to major modification.
The trems also look good Jonathan
We are also happy to say we now have stock of the blocks for the Jackson JT6 tremolo as fitted to Charvels and Jacksons between 1987-89
