Could even look into eventually having something similar for the mids too...
IME every time I've built switching in to select different tone stack values I end up having a favourite and leaving it there, so I never drill holes these days!
I’m probably going to put a different speaker in first though - there’s a Cannabis Rex in there right now, so something a bit more Jensen-voiced might brighten up the normal channel enough for low volume without needing the effect of a bright cap.
Still not quite decided between Jensen Neo Tornado, Eminence GA-SC64 or Warehouse G12C.
I'd try putting a resistor in series with the cap - try 100K. Or even a pot or trimmer so you can adjust to find the sweet spot.
R.
Eqd Speaker Cranker clone
. Imho. Like the original oxford it sounds wonderful
