Which affordable but solid 4 string?
TTBZTTBZ Frets: 2873
edited October 2019 in Bass
So I met up with some old band mates for a jam tonight and now it looks like I’m playing bass in a stoner meets post-rock sort of instrumental band, despite not actually owning a bass guitar at present.
Looking for something as cheap as possible (as in under £200, preferably lower) that’ll be solid enough in tone and tuning stability for rehearsals and recording. I like slim necks with narrow nut/string spacing. I had a Squier P-Bass and the chunky wide neck gave me hand cramps. Switched to a Jaguar bass which felt great but I didn’t like the short scale tone - all my recordings just sounded a bit limp with it. Would I be better off with a Squier Affinity Jazz?
I also like the look of Sterling Sub Ray 4, however the one I borrowed for tonight’s practice was a Sub Ray 5 and it seemed a bit dull and characterless in tone compared to a P.
Are the Harley Benton jazz basses worth a look or in this price range might as well stick to Squier?
  • Dull? What strings did the Stingray have? They’re anything but dull if you turn up the treble knob, though I haven’t tried the Sterling Sub Ray.
    Sounds to me like you’d enjoy playing a Jazz neck. A used Vintage Modified Jazz might be in budget.
    If you really want a P you could get one and change the neck for a J neck. I’m not aware of a cheap P with J neck but they do exist in the Mexican range, possibly the PJ special?
  • TTBZTTBZ Frets: 2873
    It could have been the amp I used tonight or maybe I just needed to mess with the settings more!
    I do like the P Bass tone but hated the feel of the neck. P body with a J neck might work.
  • ICBMICBM Frets: 71960
    I do prefer the sound of a P-Bass to a Jazz as well. You could look for a Squier Mark Hoppus, which is a Jazz with a P pickup, but they’re rare and probably still over your budget.
    But P-Bass necks vary enormously - everything from half a tree down to not much bigger than a Jazz, even among Fender and Squier models, and even more so among copies.
    You can get a perfectly decent P-Bass copy for under £100 second hand if you shop around, they’re so simple there’s almost nothing to really worry about, even the electrics are usually tolerable. I nearly bought a Westfield one for £75 a few years ago, it just felt and sounded great... I probably should have bought it, but it was a very unattractive shade of pink :(. You do have to try a lot to find a really great one though.
  • ROOGROOG Frets: 554
    edited October 2019
    Hi @TTBZ, I was looking for much the same and managed to find an 'Eva Gardner' Squire Bass lurking in a corner of my local Guitar shop. It has a Jazz neck with a P Bass pickup arrangement. Probably not the last word in Bass'es but it works for me.
    https://www.youtube.com/watch?time_continue=150&v=jGkb3y-lSdM
    Sorry about the whaffly video, its easier than posting a picture!
  • crunchmancrunchman Frets: 11414
    The old Squier P Bass Special that was made in Indonesia had a Jazz neck.  Also had a Jazz bridge pickup if want a bit more versatility.
    There is one on Reverb:
    Although that is more than they used to cost new!  They are good basses though.
  • FunkfingersFunkfingers Frets: 14323
    TTBZ said:
    Sterling Sub
    In current Ernie Ball Music Man nomenclature, Sterling-by-Musicman and S.U.B. are two separate brands with two different price structures and two different quality levels.
    I have.
    They are usually playable straight out of the box. The string spacing is Jazz narrow. The weak points are the cheap bridge and electronics. On the five string, ensure that the tension on the B string is firm rather than floppy.
    turn up the treble knob.
    The Powersound pickup and no-name budget active EQ are not as good as the Sterling-By-Musicman series, let alone the American stuff.
    In the nicest possible way, I hope not. (I have one listed in Basses £.) Where you might land a bargain is with the full scale Squier Jaguar Bass (PJ and H versions exist) or the unfashionable Dimension Bass.
    On the latter, the "humbucker" is actually two Jazz Bass single coils under a big, ugly plastic cover. The Jag H pickup is more like a Stingray design in a soapbar format. Consequently, the pickup cavity of both these designs will accommodate an EMG-35 series pickup. (Other brands are available.)
    Be seeing you.
    Doesn't sound like an old school precision though.
    I did think about taking the active electronics out of mine then I found a 32" mid 80's Japanese Squier P Bass.
    So I guess the best thing is to just go to a few shops and play a load then! Didn’t realise there was such variation in P-Bass necks. I liked the feel of the Jag body but felt really neck heavy even on the short scale.
    Side note, this was the first time I’ve properly played bass in a live band and I loved it. I think it suits my personality more, sitting in the back holding down the fort rather than leading on guitar got to use my DbA Fuzz War clone as well which sounds huge and filthy on bass!
    What’s 32” like for downtuning etc? My 30” Jag was useless for anything other than standard with the string gauge it comes with. We’re currently only in drop d but that might change.
  • MarihinoMarihino Frets: 0
    edited October 2019
    Last year I bought a new SX jazz for £180 in my local shop. It's a very pretty bass (sage green, chrome covers and everything) with super stable quartersawn neck and sounds just as good as my Am Std jazz. It came with horrible fretwork though that for the time being I conquered by putting flats on and raising the action.
    I've also got a Vintage (brand) P style on a layaway in cash converters for under £200 total. It's a pro instrument, and I own American, Japanese, German and vintage gear. Better than the SX in that it actually has very good fretwork and high quality hardware.
    If you might go lower then I'd go 34" over 32" personally.  I feel like 34" is the ideal choice from E down to C. Unless you specifically want 32” I think most guitarists can adapt to play 34”.  I feel like B and lower is where you’d think about longer scale.
    CAUTION: If you will be making extensive use of overdrive or fuzz, you will be best advised to play an instrument with noise-cancelling pickups.
    Traditional Jazz Bass pickup pairs only approach full hum-cancellation when their volume settings are equal.
    J-type bass guitars in your price bracket are unlikely to have dual coil noise-cancelling pickups as standard.
    For dual pickup basses with narrow string spacing, consider the Epiphone Thunderbird and Ibanez SR/SRX range.
    Be seeing you.
  • Take a look at the ibanez tmb100, if you can get on with the look of it. I have one and it's an excellent bass for the money.
  • 5redlights5redlights Frets: 317
    edited October 2019
    A PJ is probably going to give you what you're looking for more than anything else. The neck pickup on a jazz bass isn't going to get near enough to a P bass sound if that's what you like.
    Ibanez Talman basses are around £170 new. Excellent value and well put together.
    Yamaha BB basses are excellent, and used you'll definitely get one under £200. I think the new BB234s are around £260 new. The previous versions are the 424 and 414, and are anywhere from £150 to £200 used, so if looked after properly they hold on to their value well.
    edited October 2019
    In a stroke of luck a mate who no longer plays has lent me his Squier P-bass for as long as I want/til he wants it back so I’ve got this for the time being. Now I’ve just got to learn how to play the bloody thing
    I suspect I’ll still end up wanting something with a J style neck though. That BB234 looks really cool actually.
    edited October 2019
    Turns out it’s an Affinity PJ, not sure I’d the necks are different on these but feels way better than I remember the one on my old P was. Gonna try out one of those Yamahas if I can though, love the look of them.
    Being aimed at young/student players, the Squier Affinity P-Bass has neck dimensions very similar to the Affinity J-Bass.
    The Yamaha RBX series string spacing will be wider than the Squier Affinity. The lower budget end of the Yamaha Attitude Bass range is slightly wider again AND significantly deeper. Try before you buy.
    Be seeing you.
    Typically, Fender PJ basses have Jazz necks on Precision bodies.
    edited October 2019
    There is certainly a fair bit of variation.
    The neck on my 2014 Squier VM Precision Special is a compromise width and profile. The Chris Aiken signature model is the correct width but "early Sixties shallow".
    Back on topic, the Squier Affinity P Bass is a fine place from which to start. In the longer term, a few upgrades could turn it into a keeper.
    Be seeing you.
