SOLD Blackstar HT1RH Bronco Tan head and cab 1x12 - £175
Blackstar limited edition 1W valve amp (with reverb) and matching1x12 cab, barely used, was bought for spare room/bedroom but I don't really user it there.
Unmarked and as new, original cardboard packaging available if you want it.
Bristol/South Gloucestershire area.
Manufacturer blurb-
The HT-1RH Bronco Tan Pack from Blackstar features a regular HT-1RH, all-valve 1 Watt head and HT-112, 1 x 12" speaker cabinet. You'll notice a lovely new bronco tan covering to add the aesthetic flare to this limited edition mini-stack.
The stunning HT-1RH and HT112 Bronco tan pack delivers all the valve-powered punch of its standard HT-1RH brother. Dressed in bronco tan covering and sleek metal corners it’s also more than capable of driving a 4x12! Featuring two footswitchable channels, Blackstar's patented ISF control, and a lush digital reverb the HT-1RH Bronco tan pack is guaranteed to sound as great as it looks.
Blackstar HT-1RH And HT112 Bronco Pack Features:
Anything that might float your goat trade wise?
Based on this I doubt anyone will still be interested but if you are, pls say so and we can discuss/negotiate.
Only kidding
Most carriers are more concerned with size rather than weight.
I bunged in a 25kg weight & under 1 metre size (no postcodes) in the UK.
https://www.parcel2go.com/quotes?col=219&dest=219&mdd=0&p=1~25"etype=Default
If nobody local or within mutually acceptable driving distance buys it I think I just talked myself into keeping it.
All that I would say is that from my experience of relating to members here, I doubt that you would need to worry too much about negative experiences. A ridiculous, sweeping statement, but from my perspective, it's true.
If I didn't own far too many amps (including a Blackstar HT1R) I'd buy yours & take a chance on shipping, just 'cos it is soooo pretty
Cheers.
I had a Blues Junior delivered last year which I actually saw the courier driver drop as he unloaded it from the back of his van. Only about a foot or so, but still. I took delivery but informed the shop I'd bought it from. Sure enough, it had loud crackling noises, a blue flickering valve too, which was probably due to the impact, but who can tell....anyway,to their credit the shop swapped it out without question.just made me a little wary of couriers....
Thanks
