If you want the best capo available on the market, go for an Elliot.
Check out my YouTube channel for videos of luthier-built and vintage guitars!
Luthier Stories - My series of interviews with some of the world's greatest guitar makers
Elliot is so expensive - can't say I'll be getting that...!
My YouTube Channel
You need to fit it exactly along the back edge of the fret crown, so it can't pull the strings down into the space between the frets. It sounds tricky but it's actually easy once you get used to it.
G7/Jyser sound like a good bet, thanks!!
My YouTube Channel
I'm now also aware of a slight buzz on my acoustic's G string (seems to be coming from the bridge??). Argh I give up!! Time to learn keyboard!!
Decided to return this to Amazon and stick to the shubb types. I'll check back through this thread to see if there's similar with a more rounded back to them.
My YouTube Channel
I see that the Performance 2 was discontinued in January and replaced by the slightly more expensive Performance 3, which reportedly seems to be suitable for a wider range of necks (including nylon-strung hybrids)
Thought about version 3 bit decided against as read was heavier.
Must say I'm really disappointed given the reviews on it.
S3 or S3VN look ok: http://www.shubb.com/store/capos/3.html
(EDIT: ordered the S3Vn)
What's annoying now is this buzzing coming from the bridge..
My YouTube Channel
My YouTube Channel
