So after the recent discussion on who uses metronomes, and my admission of a pathological hatred of the little beggars, I thought I should ask for your thoughts...
What alternatives are out there to practice to?
without the psychologically disturbing "click" that takes hours / days / weeks / months to get out of your head.
Manufacturer, model, apps for phone or tablet, bring out your dead....
Any ideas would be appreciated, especially as it seems I am not the only one who hates them.
And I do think that a good groove goes way beyond the constriction of a midi file, so if there is anything out there that fits that bill then please share.
This or a Roland drum machine - they have a range of styles with bass or you can program your own with full control over the tempo so you can start slow and build up your speed. I have a DR-880 which I've used for years. It has guitar tones so you can plug your guitar in, select or create a tone, pick a drum track set the tempo and jam through headphones. An all in one practice unit.
http://www.roland.co.uk/products/subcategories.aspx?c=69
Obviously you can do this on a computer through a DAW or similar.
There are of course other alternatives but a half-decent drum machine plus a "Rhythm Pattern Dictionary" which tells you how to program beat patterns in a variety of styles, is very instructional.
The nice thing about the SR-16 is that it is just a drum machine, leaving you with all the guitar sounds and everything else you might want up to your own choices. Whereas some Boss or Zoom products with it all in the same box will lock you in to their versions of OD, distortion etc which might not be what you want.
The guitar tones in the DR-880 are good enough to practice with ...
http://www.bossus.com/gear/productdetails.php?ProductId=115
http://www.soundonsound.com/sos/1994_articles/may94/bossdr5.html
I've used a Line6 DL4 for years (quite basic looper) but I've just acquired a new Digitech JamMan Solo XT - this gives you basic beat box style accompanyment if you want it plus is fully linkable to a computer via usb so you could load it with any percussion loop you wanted.
I say primitive, but to be fair I've worked with drummers who know fewer patterns...
How much are you after for you dr's?
I will PM you just now.
