WITHDRAWN: Fender Original Vintage Tele Neck Pick-Up
subfeedersubfeeder Frets: 5
edited December 2019 in Parts £
For Sale: Fender Original Vintage Tele Neck Pick-Up
Good condition and includes screws and grommets
  • So is the neck pickup working? It's not very clear from your wording.
  • Hi, yes neck pickup working. Just the bridge has intermittent fault.
    I will update the wording for clarity.
    Thanks
  • bump
  • FunkfingersFunkfingers Frets: 14323
    Please will you describe the intermittent fault. Can you get a DC resistance meter reading from the two soldering eyelets on the vulcanised fibreboard?
    Are the rod magnet polepieces on the bridge pickup for the D and G strings slightly raised above the bobbin plate or are all six the same length?
    Be seeing you.
  • Hi Funkfingers.
    As I remember the fault (it was a couple of years ago) I fitted the pickup and it worked for a few hours and then the sound became very thin. I took it out and put it back in (after checking with another pickup) and pretty much the same thing happened. So I suspect an intermittent short circuit somewhere in the coil. I will try and DC meter it soon and check the polepieces.
    To reiterate and clarify, the neck pickup is working fine, it's just the bridge is faulty.
    All the best
    John
  • Bump
  • Bump
  • Bump
  • Bump
