FS Jensen neo 10"s, Celestion G12L40 4ohm
Smooth and balanced sounding speakers. Great for lightening a 2x10 combo or adding clear low end where needed. Rated up to 100watts. 8ohm
http://imgur.com/a/7HjRKuD£55 posted each
Added:
G12-L 40 possibly used in 90's SS Marshals.
Sweet sounding speaker for a low to medium powered valve or SS amp
http://imgur.com/a/DAcpgxw£30 posted
Sold on ebay: 70's champ cabinet
Has a great Weber heavy magnet ceramic 4ohm (3.2ohm) 20watt speaker,
8F125T
Includes traditional speaker connector, top plates and bolts (no nuts) and feet. As shown with lower backplate.
http://imgur.com/a/c65UpoF£127 posted
Sounds good, I've got a musicman sixtyfive 210 which has currently got a pair of Fane Axiom 10"s which do sound good, but they're wired to 8ohm. The extension is wired in series which means I've got know where to go from here, and I've got an old matching musicman ported cab, also a 210 which is 4ohm. So I've been thinking about switching out the speakers for some time.
With christmas coming up I'm having to be a bit restrained with adhoc purposes, and the amp doesn't get moved so it can be fairly heavy, the 210RH also tends to be on bass duties in the studio. But I'll keep an eye on this thread. I think it's probably going to be till January payday before I can splurge on gear.
