I'm mulling over a small acoustic amp / PA. I currently have 2 electric amps (5E3 and PRRI), but would like to do more acoustic and as I do backing vocals would use it as a personal monitor. So am looking at swapping the PRRI.
I play mainly in an acousticish band anyway, I usually play cleanish electric with this through my amp, which isn't micced up. Vocals go straight to a single PA speaker (which is usually out front, so not great for monitoring, but volumes are lowish so it's not a massive issue).
So I'd like something to fulfil the following:-
-Good acoustic guitar sound (I currently use a Fishman UST and IR's through a Helix, but will change to either a Seymour Duncan Mag Mic or K&K mini)
-Good for vocals, nice monitor or small audience sound.
-Okay for electric guitar - I may on accation want to use the Helix through it. I play mainly cleam, Jazz, Blues, Country, Reggae etc.
-Reasonably small, lightweight. Versatile mounting / positioning.
So currently looking at:-
AER Compact 60 - Probably best guitar sound, most compact. Expensive, not sure on vocal sound.
Bose S1 - All rounder, has vocal and guitar settings, versatile I/O. More powerful than AER.
Yamaha DXR8 - Most powerful, but less acoustic guitar orientated. Heavier but more robust.
Thoughts?
Feedback
I've got the original 6 model (discontinued now I think) and to me it sounds better than the AER Compact 60 while being in the same general ballpark. I find it a slightly more natural and neutral sound, more like a small PA. I like the AERs too, but they can sound a bit 'overly enhanced', if you know what I mean...
The main issue with it was the covering which was like paper, marked/ripped so easy, but I believe they have changed it now.
With a decent pickup and that clarity can work for you. The Fishman was a little more amp like, but sounded good.
Could look at another one of those. I do like the stand mount and size of the AER though. But double the cost…..
I think I think I tried one of those years ago under a different name, sounded ace but no reverb.
Not a show stopper though. I actually prefered it to the AER, it was bigger and warmer sounding, but I put this partly down to my pickup (Fishman Matrix) needing some warmth as it was quite harsh. With another pickup I'd try the AER again.
They sound great for instruments, though I've never put vocals through it. I have used an AKG 414 to mic my classical guitar and that sounded beautiful, so I would imagine it should handle vocals ok.
I think it's rated at 120w so potentially higher headroom and more volume than the AER 60, but without doing a real comparison that's just a guess.
Recently a friend used mine and had his 12 string in one channel, his 6 string in another and his mandolin in another. All of them sounded great. I happened to be on percussion that night.
Wanting it to work with an electric is tricky... guitar amps and speakers are very far from flat response and add strong colouring. Putting an electric through a much more hifi acoustic amp is likely to sound thin and overly bright.
Even with amp-emulation, be careful - acoustic instrument amps are designed for clean signals which have a high ratio of peak to average power and neither the amp or the speaker may like being pushed harder with a more sustained overdriven sound.
Feedback
