SOLD: Bad Cat Cub III 15R 1x12 combo, handwired
fretfinderfretfinder Frets: 5019
edited December 2019 in Amps £
SOLD
Bad Cat Cub III 15R 1x12 combo, handwired not the cheaper circuit-board ‘player series’ model. Immaculate condition with two-button footswitch to change between the two preamp valves (one 12AX7 and one EF86) and to operate the boost function. You can also switch between preamp valves and operate the boost from toggle switches on the front panel.
It’s a very versatile amp that can give you a cleanish sound through the 12AX7 preamp valve and a crunchier sound through the EF86, and then it has the boost, the K-Master master volume, and of course reverb. There’s also a toggle on the front panel to choose either individual treble and bass controls, or a rotary switch with five preset eq settings. On the back panel it has an FX loop with send and return sockets plus an extension speaker output with switchable impedance. The latter is very useful if you want to use the internal speaker and an extension cabinet together, with the right load. The amp is very loud for 15 watts with excellent clean headroom but thanks to the master volume is also very useable at home.
Asking price is £1200. Collection from Salisbury in Wiltshire or I can deliver within a reasonable distance for petrol money. Thanks for looking.
https://i.imgur.com/zSd2Ra6.jpg
https://i.imgur.com/HuCv9KA.jpg
https://i.imgur.com/T5hvjJ6.jpg
