Can you do a PhD without doing a masters?
Asking for a non-existent friend.
Bye!
  • John_PJohn_P Frets: 2749
    edited December 2019
    Yes.
    Or do one with a masters along the way that you continue in a PhD if you are still interested.
  • prowlaprowla Frets: 4915
    Yes, afaik you can't do a PhD on the same precise research as a masters.
  • There's nothing to legislate against it, whether it would make it harder to get a place is another matter.
  • Adam_MDAdam_MD Frets: 3420
    Yes my wife did her phd without having a masters.
  • ToneControlToneControl Frets: 11884
    AFAIK usually only if you have the domain knowledge required for the PhD covered in the B.Sc.
    e.g. no PhD in Computers with a BSc in Physics, normally do a "conversion" taught+dissertation 1 year MSc in between
    It's a hell of a lot of work for little reward unless you want to work in a Uni
    In the old days, you could register part time for 5 years instead of full-time for 3, and the yearly fee was 10% or something. I'd take a look at what there is around Europe too.
  • ColsCols Frets: 6987
    Yes, you can (I did).  Normally a 1st or 2.1 is required to go straight from a BSc into a PhD; with a 2.2 a Masters would likely be required.
  • Yes. You’ll probably be registered for a masters by research (M.Phil) and then have your work reviewed after 12 - 18 months. If you’ve made good progress then you’ll convert to a PhD and continue your research. If the quality / quantity of your work is not up to scratch, then your supervisors may recommend that you write up for an M.Phil.
  • You can, but my daughter, who’s recently completed her Masters in BioMed (got a 1st, and it’s her graduation ceremony today) tells me that most people do a Masters before they do a PhD these days.
    That’s how it was in my day. People only did a masters if they really wanted to do a PhD but only got a Desmond. If you got a 2:1 or first there was no point as it just cost you an additional two years.
  • sgosdensgosden Frets: 1993
    My brother did biology degree > worked in a lab doing some sort of genetic research (which I can never really understand) > just started a PhD in the same department this year.
    He was in the subject field for 4/5 years with his name cited on research papers, and had previous applications knocked back.
    So doable but not easy in his case.
  • LuttiSLuttiS Frets: 2243
    Mrs. L did masters then on to PhD. My brother failed his masters (glug glug), then through his work sort of got into academic field and is now doing his PhD through there as it directly relates to his work.
    My understanding is that you can go to PhD without masters, but your very unlikely to get it funded.
  • You will end up paying a shitload of fees.  They aint cheap
  • tony99tony99 Frets: 7104
    You don't necessarily need to pay for it though.
    Bollocks you don't know Bono !!
  • fields5069fields5069 Frets: 3826
    This, that's how it was explained to me in 1990 anyway. I got a Desmond, so next I did a Masters but then still couldn't be bothered to apply for a PhD. It was all about spending the most time possible away from the real world, so 5 years wasn't a bad shift.
    Some folks like water, some folks like wine.
    My feedback thread is here.
  • Both my kids have PHD's.
    My daughter went to Imperial to do a degree ,then wanted to continue and do a Masters and this led to a PHD in Entomology.
    She liked insects.
    My son did a Degree/Masters at Manchester. He wanted to carry on and did his PHD in Theoretical Physics.
    Was at CERN for a year .He graduates in a couple of weeks time.
    He loves Physics.
    They both did what they loved. I didn't pressure them, but did support and guide them.
    If you do what you love your brain absorbs the information, makes it a bit easier.
    I helped with their accommodation and food ,spending money etc.
    They both started before the fees went up.
    There was a lot of stress ,it is hard work.
  • NPPNPP Frets: 236
    it is definitely possible. Entry requirements are set by individual universities or even departments within them so it's best to check locally.
    There's FindaPhD.com and jobs.ac.uk where funded PhD opportunities are advertised. Some of them may be part-time. 'Collaborative funding' is all the rage now so if you can get an employer to contribute a little bit that might be an option. Such a contribution doesn't have to be 50% and can involve time, use of equipment, expenses, mentoring, not just real money.
    All that said a PhD is a long, hard slog and you should know why you are doing it and how you will cope with the anxieties that develop along the way before embarking on it. If you are after a qualification to enhance your career outside academia rather than after a (very uncertain) academic career then maybe a masters would be preferable (shorter, cheaper, not taking you too far away from the professional world).
  • FunkfingersFunkfingers Frets: 14411
    John_P said:
    Yes.  Or do one with a masters along the way that you continue in a PhD if you are still interested.
    Beats getting a job.
  • fobfob Frets: 1430
    What do you want to do a PHD in? Or to what end?
    I generally think people would be better off stacking MScs than doing a PHD if it is specifically for employment purposes.
    It's his friend, I think he's pretending to have a friend
    Congrats to your daughter!  That’s awesome.
    Naturally there may be an element of competition, depending on how prestigious the place is (e.g. PhD supervisor is a world-renowned scientist at a top level university) and what the funding is.  If there are two otherwise equally qualified candidates competing for the same place and one of them has an MSc, you’d pick that one.
    Apart from that, there’s the question of time and money - generally an MSc is at least another year out of your life, and if you subsequently go on to do a PhD your potential employers are going to be taking you on the basis of the PhD rather than whatever you did before.  So if you can get away without doing a Masters to get a PhD placement, do it.
