SOLD - Vintage Laney Supergroup PA60 Circa 1971 Partridge Transformers Valve Amp
Looking for £995. Postage would be £15 within mainland UK, and will be extremely well packed.
Vintage Laney Supergroup 60 watt PA head, probably circa 1970 / 1971.
Appears
to be mostly original including the sought after Partridge
transformers. Although I am not an expert on amp electronics and have
included the gut shots so that you can inspect them for originality.
Amp
is in good working condition, apart from input 1 which is not
functioning as it should and probably needs the pot replacing. Inputs 2,
3 and 4 are working fine. Great tone from this amp, and starts to break
up nicely at higher volumes.
EL34's are Svetlana, ECC83's appear to be a mix of Brimar and Mazda.
