R.
Eqd Speaker Cranker clone
Feedback
Quality is always more important than volume. Always.
The mistake people make with mic'ing drums and putting other wild transient and low frequency instruments into a PA is not processing the signals. High pass filters and compression can make life a lot easier for the PA and result in a cleaner sound and less failure of gear. With this in mind the type of desk you use is more important than the type of PA when it comes to mic'ing everything
Not sure what else to say - I'd stick to minimal instruments in the PA, keep the volume down, and watch the bottom end.
Failing that, where are you, and what's your budget? I could pop down with my rig (unlikely to be viable as I'm in York)
R.
The most complex thing is ringing out the room and you just need a graphic EQ for that.
It takes 10 mins max and you can learn how to do it by a youtube video.
With regards the venue posted by the OP, that looks like a typical village hall type setup which will carry the sound really well. I would think you could get away with a mic on the kick and an overhead and it will sound fine.
On another topic related to the post, what's the secret of mixing the kick drum and not getting a load of bleed from the floor wedges which, in a typical gig, are about 6ft away.
Behringer ECM800 for around £30. I have one and they would do the job in a live situation.
They work well.
R.
