Hum and fuse blow help
Rich210Rich210 Frets: 577
Hi guys and girls,
I was playing bass through the head of my musicman sixtyfive in a Aguilar db115 and when I turned it up the fuse blew.
I replaced the fuse, lowered the volume but instant hum and then blew another fuse.
Both of the tubes light up and no obvious damage to the vacuum. And they're newish tubes.
I'm running JJ kt88's and revised accordingly. The plate resistor is 220k, most reconnections is to swap this out for 100k but as it's only 65watts I thought it would be fine as per the spec sheet of the tubes..
Any theoretical wonderings appreciated!
Best
Rich
  • ICBMICBM Frets: 71963
    New-ish or not, the chances are it’s a blown power valve.
  • Rich210Rich210 Frets: 577
    Thanks pall, could you hazard a guess of why it might have blown other than a defective tube?
    Best
    Richard
  • ecc83ecc83 Frets: 1592
    I am confused by "Plate (proper name Anode) resistor 220k" ? and KT88. Do you mean the grid leak?  If so I would have thought 100k  a bit low for the PI driving it although low GLRs are otherwise a good idea.
    When I had 88s die The Purple Death they cooked the 10k grid stoppers. Did not change value but went very brown!
    I don't think KT88s from any new source are as tough as the originals?
    Dave.
    edited December 2019
    It’s actually a very unusual amp design that operates with very high voltages (700V HT) and can be very hard on the valves. The resistors in question are the grid stopper resistors and should be 220R (not K).
    A common mistake is to bias them way too hot, they need to be set using a scope rather than by power dissipation, just above the point of crossover distortion.
    https://drtube.com/schematics/musicman/gp3a.gif
    Seven hundred volts! I am sure Balckstar will not mind me telling you that the S1 200 had the transformer revamped to drop the HT to around 650V iirc on the Anodes. This was purely because it proved impossible to find KT88s that could take the rated Va of the orignals.  Well, not at least at a price that was practical for a guitar amp!
    The valves are biased to 25mA  so Pa is very safe 16W or so. There are of course 4 valves.
    There is also an an anode fast fuse and an interlock to stop the beam plates melting if it blows!
    ...In'ell! Just noticed the transistors in the 88 cathode circuits! I bet they have gone home to the great Silicon graveyard in the sky.
    Pretty daft idea if you ask me? Especially with KT88s in guitar amp.
    Dave.
    Indeed, personally I wouldn’t put modern KT88s in one either.
    The best valves for these are old-production US 6550s.
    Thanks for your input as ever,
    The amp is 2100-65 chassis that should have 6CA7's
    http://www.thetubestore.com/lib/thetubestore/schematics/MusicMan/Musicman-2100-65-Schematic.pdf
    Thanks for the feedback, I'll take her into Matamp on the way to work and let them give it a once over.
    I was hoping it might just have been a case of swapping the tubes checking the bias and replacing a resistor.
    It's a really good bass amp, probably end up with some E34L's in there a see how it goes.
    Ah, OK - but even so the same things about HT voltage (even higher, 725V) and bias apply. There are no 220K resistors in this one either, the grid stoppers are 1K5.
    If you can’t find any old-production KT88s at a sensible price you would probably be better with old-production EL34s - despite the lower power dissipation, they’re rated for 800V.
    Well I had new production JJ kt88's that were rated at 800v. I think JJ EL34s are up to 2000v which seems to good to be true but there you go. It was running on some siemans el34 and I switched them over to the 112rp65 version during the service.
    The plates actually run at 780 volts on the 210 sixty five....
    @ICBM ; so out of interest what is R55 on the schematic? Its 220r resistor, I got mixed up before.
    I wouldn’t believe the voltage ratings on any modern-production valve, to be honest.
    Servicing MusicMan amps in the 90s was interesting... pretty much any new valves would just blow immediately. They have at least got slightly better since then.
    So what would you say is the best new tube out there to put in it?
    I'll keep an eye out for NOS stuff!
    It’s very hard to read that schematic but it looks like it’s the grid stopper for the top power valve, and is 1K5. I can’t see any 220s in this one, which is why I thought it was the other circuit.
    No, can't be true.  I reckon the valve base wouldn't take it, it would arc over.  Just looked at the datasheet, pretty scant compared to valve datasheets of old.  They show "Ua0" = 2000V.  I'm guessing that's a maximum voltage with no anode current flowing.
    @ICBM the clear schematic is on the third page I think.
    No wonder I’m baffled, that’s a completely different amp to the one on page 2!
    Yes, R55 is the grid stopper and is 220R. I would definitely not lower the value.
    @ICBM ; ok cool! So when you read about KT88 mods, there's a resistor change from 220r to 100r what's that about or is it not relevant to musicman amps?
    Some people have used kt88's in the rd100 which is another interesting amp design in that it produces 100watts while having only 2 6L6GCs.
    Another thing, do you think it's just shitty tubes? This is actually the second set of KT88s it's destroyed. The first blew when I clicked the deep button as my mate was playing quite loud. It actually cracked the bottle. These tubes were returned and replaced as defective.
    No idea, I've never put KT88s in a Musicman. I have used 6550s in the 6L6 models, but always old-production GE 6550As.
    That's because they run them at very high voltages and biased almost to Class B. That's what I meant about many people biasing them far too hot - if you try to do it like a conventional Class AB amp, you'll blow the valves.
    Quite likely, as Dave said from his work on the Blackstars.
    It's unfortunate that these amps were designed for the quality of valves that was available in the US in the 1970s and really pushed the technology to the limit.
    Dave.
    Hi Dave,
    I was getting a bit confused to be honest. I was talking about a 220r grid leak, but I got muddled when reading KT88 specs and trying to put two and two together!
    I'm learning that I probably shouldn't have swapped the EL34's out for KT88's even with a sensitive rebiasing. I was advised to run them at 780volts to avoid impedance issues (the amps are switchable from 720 to 350 on spec, mine runs 780???), but it looks like where one preventative action was made a risky action happened in light of less than military grade modern tubes. At some point I'll take it to someone around Manchester that knows a lot more than I do.
    I'm probably gonna ditch the KT88 journey in the sixty five, as the impedance miss match with the output transformer might be an issue. The impedance of the output transformer is 9.5k. And it's clearly impossible to get hold of decent tubes that don't cost the same as the amp itself is worth! So I'm looking out for reasonably priced EL34s that'll do the biz...I've heard that JJs output tubes are getting sketchy, even the E34L which was a tube recognised being able to cope with these designs.
    @ICBM I can see why these amps go for not a lot these days, clearly there are issues with finding tubes that can keep up with the design. I love the tone that these produce! Maybe they're only good for running on the 350volts setting.
    Thanks again for both your input
    Richard
