The Schaller pickup is probably from 1986 and pulled from a Kramer.
I wondered if it was some sort of hot Mustang pickup, but I can't find any reference. I also seem to remember reading somewhere that very early Quarterpounders had slightly smaller poles, but again I can't find anything. What is the DC resistance? That might help give a clue.
I know nothing about the Schaller, other than that every one of their pickups I've ever heard has sounded poor!
Quarter Pounder is a registered trade mark of McDonalds. I never understand why people insist on misapplying it to Seymour Duncan pickups.
Of necessity, the rod magnets in an STR-3 are smaller than other QP models.
The Schaller humbucker might be easier to identify with d.c. resistance meter readings.
I gather that means the Schaller is trash
But from the DC resistance it does sound like some sort of Quarterpounder.
No, just fairly low output.
Gretsch Filtertons have a much lower DC resistance than that and sound great.
Or sell them
Er, have measurements of the fibreboard plates, the rod magnet diameters and the distance between the mounting screw holes been provided? Those could prove enlightening.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Mounting screws are 78mm from the centre of each of the screws
It doesn't seem to correspond to any Duncan pickup I can find specs for.
Either the pickup has undergone a rewind or the upper fibreboard plate has worked unstuck and migrated upwards. Normally, they just curl up at the ends, like a British Rail buffet sandwich.
I think it’s most likely to be an old and discontinued model, probably a rare one that was not made for long. I don’t know where I read about very early Quarterpounders having smaller magnets - which would technically make them Threesixteenthpounders anyway - but it’s about the only thing that makes sense from the dimensions and winding...
On the Stratocaster QP flush pole pickup, the model number is SSL-4.
A Stratocaster pickup of high d.c. resistance, with 3/16” rod magnets and the model number 3 is an SSL-3 Hot.
The SJAG-2 is, to all intents and purposes, the same thing as the SSL-3.
