Snapdragon are an interesting UK make of silent and travel guitars but they only do steel strung.
I came across an incredibly expensive German make a couple of years ago - Frame Works. I don't know if they are still going - they didn't bother to answer my e-mail enquiry. They look a bit like a better engineered Sinsonido - but at prices that would make your eyes water.
Carvin/Kiesle make a classical thin body (with no sound hole, like a Godin). I've never tried one of these but I've got an old 2000 Carvin CL450 thin bodied crossover which knocks the spots off a Godin - but also has a better acoustic sound (and a sound hole) - so it can't be described as silent. The CL450 is no longer made but occasionally appear on the second-hand market.
I've previously thought that a silent classical would be interesting to design with help from a luthier to make it happen. I'd forgotten all about - until now!
cheapo £150
https://www.dv247.com/en_GB/GBP/Red-Hill-MEC-01-Nylon-Electro-Acoustic-Natural-/art-GIT0043522-000
48mm nut
btw, that's just the first one that I noticed
this thread's request would be to use with higher volume and lots of FX
My experiments were to use a silent guitar with a DAW-compatible guitar synthesiser (MIDI Guitar 2 from Jam Origin) - which will produce a decent polyphonic output from a standard 1/4" jack. I found thin-bodied classicals like Godin produced too much acoustic volume which mean having to wear headphones or ramp the amp output up high to avoid interfering with the synthesised sound. I heard of someone actually stuffing the body of a Godin with padding to avoid this.
the pack-away silent ones look good, but a tele-shaped one looks more normal to me, not sure which would be comfiest
The frame made it more comfortable to play although, in retrospect, it would have been better being a bit larger. In retrospect, if I did this again I would cut the frame shape myself from a blank set. Having said that, MDF would probably be OK and a lot easier to work than a hardwood blank. The pre-amp worked well but was a bit noisy. I eventually sold it as a project on eBay with some other bits. Photo below. If nothing else, it was a head turner and also fun to do in a strange sort of way.
