Kluson Deluxe 6-in-a-line locking tuners SOLD
19791979 Frets: 87
edited January 2020 in Parts £
A set of tuners taken from a Jazzmaster custom build that I bought with the intention of doing up. I’ve lost interest in it as a project so am just splitting it for parts.
The shaft diameter is 6mm and the bushings take it up to 8.7mm. I’m not altogether sure what the imperial equivalent is to that.
String Post Overall length including cap= 30mm
String Thru Hole ctr Height= 19mm
https://imgur.com/gallery/mO8X0Ip
  • I am interested, if the tuners are still available. I assume they will fit standard tele or strat neck?
  • 19791979 Frets: 87
    I can only give you the measurements I have taken. They came out of a custom built neck so I can’t check that they’ll fit a standard neck mate
  • PMd
