FS:- Fender '65 Princeton Reverb Reissue SOLD
Fender Princeton Reverb Reissue for sale.
Good condition, recent upgrade / service from Gartone.
The amp is a little different from stock and quite a bit cleaner and louder. Both transformers have been upgraded, the OT is a Allen Amps TO20, wound by Heyboer USA. Stock OT will be included, if you want the softer, fartier bass of the original, it's an easy swap.
Power Transformer is now a Hammond 291 AEX. The amp went to Gartone due to a fault and it turned out to be the Power transformer, so this was swapped for a better hammond unit.
While the amp was being fixed, it had new F&T power supply caps and better bypass caps installed. New Rectifier and power tubes installed, amp was re biased and set for 240v. I paid extra for these mods as they were all said to be improvements for both tonality and longevity. There was damage to a track in the PCB, but this has been bypassed by a HT fuse which should be there for protection anyway.
The speaker is an Eminence Ragin Cajun.
Footswitch is included but one of the footswitches switches needs replacing. There's no cover with the amp.
https://i.imgur.com/MQX5vvm.jpghttps://i.imgur.com/7fpqCut.jpghttps://i.imgur.com/J9DPit6.jpg£600
It’s now a blackface clean machine!
Quality caps, new valves, quality iron.
Has put on a bit of weight though, but who hasn’t after Christmas
Final forum bump at £600.
Final final bump
Stock was 15.4KG.
