telepaul build finished
  • Wow that's amazing work!
  • CorvusCorvus Frets: 2925
    Nice to see those pics Darren, good stuff. I'm getting sold on the pin/overhead setup more & more, just been to see my mate's ones.
    That board is psychedelic ... dead good.
  • DanielsguitarsDanielsguitars Frets: 3288
    I got a pin router after making my first Les Paul years ago, especially doing them vintage style, any other way is just a pita, I also like pickup routes on the neck plane
    The other thing is I like seeing what I'm doing, it's easier to stop any bad mistakes
    Get one, you'll wish you did it years ago
    www.danielsguitars.co.uk
    (formerly customkits)
  • PeteCPeteC Frets: 409
    Could you show a few pics of your pin router set up Darren ?   really interested in how your set up works.
    Your latest build is spurring me on with my first and now second build - great inspiration.
    I'll try just bear in mind it's not the holy grail, I had to make compromises and learn how to get the best out of it, I'm up one flight of stairs so can only have a small one, I'd love a big charnwood or wadkin, no way that's getting in my place
    Mine came with a Watford motor which was pretty useless tbh so I had an engineer friend make me a beautiful bottom plate to take a big elu or trend motor then it has to have the extension which isn't ideal so I had Mr engineering man make lots of different pins, different lengths and some oversize too to compensate for any runout, I've got it working well after the initial agro
    You can get away with using a table router imo it's just carved tops are a pita and why I have the overhead, wouldn't go back to using anything else, I use a small hand router for tiny jobs if it's easier
  • Looks like it'll be a beauty Darren.
    I'd love to see it person when it's done, I'll give you a shout sometime.
    I have a fretboard glued on a neck now, first I made up shims for the board to sit on then made flat with the overhead, I have a slight angle so jack up the body a tad route most of it off and finish with a scraper, the board now sits perfectly flat
    Next up fit dot inlays and side dots, this is tedious but we're done, I'll glue the inlay dots in tomorrow, I pin the board on the neck for locating when I use the hot hide glue, it's quick, glue, pin and wrap
    We're back now the neck joint has been fully fitted and it's come out lovely, shims trimmed and necks been carved leaving just finish sanding etcI trim the neck with the overhead get it almost flush then it's chisel and sandpaper
    Now a bit of neck carving and this is what I use, for sanding I use some MDF with paper on it, a rubber squeegee and a radius block, the Japanese saw rasp is fantastic for getting a neck done fast, it takes material off quick
    Very nice indeed and great pics.  Those Shinto saw rasps are brilliant tools.  I think it’s my favourite tool in the workshop.
    This is routing the pickups, I always route them after the necks in, it means I can get them exactly where they're supposed to be and it all came out spot on, I did have to make a template for my carrier board first , I used my other goldtop template to route the middle part of the p90 pickup
    Next up get the fretboard finished, I sit the neck on a simple jig that I use to flat the fretboard before fretting and it really pays to do this, I've strung it up and it's had no fret work and plays great with a low action, I'll still level crown and polish but there's not much work to do
    We're nearly done, it's strung up and so happy with how it turned out, it's playing lovely straight away, just body contouring and a bit of neck profile tweaking then I can finish it, it's 7.2lb now
    0reaction image LOL 4reaction image Wow! 1reaction image Wisdom
  • poopotpoopot Frets: 9099
    Played this this eve... absolutely banging!... well done... whoever gets this will be well happy!
    Cheers Stuart, glad you like it, I do
    Things have moved on a fair bit, I moved the cutaway back sculpted the body and cutaway then sloped the body down to the heel, anything that makes it comfortable and easy playing
    I'm onto finishing now so I thought candy apple red body and burst the neck to show the flame maple, headstock will get the candy treatment, i really like this look
  • Philly_QPhilly_Q Frets: 22742
    I wasn't expecting all that body contouring.  Very interesting...
  • webrthomsonwebrthomson Frets: 1031
    Hot damn - that is amazing - looking very nice indeed! :)
    edited March 2020 tFB Trader
    Never mind interesting, it's more comfortable and practical, anyone can order with or without, this is my vision of a good modern les Paul, it's still got the neck and fret scale of a vintage guitar
    Forgot to say I don't like how some LP are routed for better access, looks nasty to me, it's just a quick whack round with a router and no finesse
