The Underdrive was a Mad Professor pedal.
Can be done with any good EQ pedal.
now I’m torn between buying the EQ200 which I don’t really need right now as I’m stuck at home and the LS2 which I also don’t really need right now.
If you can't find a second hand EQ200, there's the older EQ-20. There are two in the shop I work for, but unfortunately they're closed at the moment...
and it’s quite cheap.
I think I’ll do that for now!
thanks
Connect the guitar to the pedal input, the B send to the amp's input, the B return to the amp's FX send, and the pedal's output to the amp's FX return. Select A-B on the Mode, not bypass. Essentially you're then running the amp's overdrive section as a "pedal" in the B loop. I would set the B loop level to the centre - that way it won't affect the range of the controls on the amp. The A level should then give you enough boost to match the amp's volume.
You can then also run different effects in the loops - if for example you only want chorus or reverb on your clean sound not the overdrive, just put the chorus/reverb pedal in the A loop.
I should probably mention that I've never actually done it on a Jubilee . Just on a couple of other amps with this problem - but I'm sure it will work.
I'm eagerly awaiting the lovely people at Hermes to drop me a Mini Jubilee, and from what I have read, I'm anticipating similar issues with clean / dirt balance... which might be a problem if I ever get to play a gig again!!
musteatbrain... how did the LS2 solution work out for you? I'm not sure I've 100% understood. Are you bypassing the preamp completely for clean, or just dropping the level in front, then boosting again in the loop?
http://www.thefretboard.co.uk/discussion/57632/
I’ve stopped using it that way though as I stumbled on a setup I like more.
It can’t be used to lower the signal going in to the preamp whilst boosting in the loop unfortunately.
I now usually have a very simple arrangement:
P between 4 and 6 based on the guitar
B 8.5
M 6
T between 2 and 4 based on the guitar
G 6
Clean channel sometimes gets a clean boost in the loop.
Lead channel gets a juansolo modded tubescreamer.
gain at noon, volume at 3 o’clock tone at 9 o’clock.
This makes a similar sound to the gain of the amp being on 8 but it feedsback a little sooner, with the compromise of a little hiss.
I tend to use single coils on the clean channel and humbuckers for the lead. I almost never use the rhythm clip.
this is the most balanced setup I can find with my setup of guitars and speakers.
I’m writing this in so much detail as a reminder to myself as well, because my one year old loves to set the dials on it.
The settings I use are actually based from a video on how John Frusciante uses his on the clean channel.
