But perhaps most importantly it looks like it could be at least another month or two until Pod Go is readily available in the UK. As at today Thomann are indicating 5-7 weeks, Andertons are (supposedly) expecting a delivery on 29th June. Gear4Music are indicating 3rd June but that seems mega optimistic. Peach Guitars and Amazon are not showing any expected dates.
I'll be interested to see if dual cabinets are included, my perusal of the manual suggests not - I imagine they're dsp hungry?
So far that's the only thing that I really enjoyed on the LT that this won't have, amp modelling wise. I found almost always it sounded best with the impedance fixed at max as in the HX products too.
The cosmos echo and legendary drive would be missed though! The former is becoming a fast favourite on my HX FX...
I honestly would have considered the Helix LT - but weighing in at 12.45lbs and around 12.5" x 21" it's just too big and heavy and I really want and need something that's a lot smaller and lighter than my Tonelab SE (13.67lbs, 27" x 9.6"). The Pod Go would be just perfect from that perspective (14.1”w x 9.1”d x 3.5”h; 5.2lbs).
No dual Cabs on the pod go.
Flogging the dead horse..
In your personal case, I would set Global Settings > Switches/Pedals > Snapshot Mode to "Toggle." You only have to press Up/Down together once. (POD Go will even remember that you were in Snapshot mode.) So:
- Press MODE (one switch) to toggle between Stomp and Snapshot modes
- Press either Up *or* Down (one switch) to view/queue preset banks; selecting a preset (one switch) instantly returns to Snapshot mode
100% optional, but you could also set Stomp mode to "4 Switches", which would give you preset queue access (again, from a single switch) from within Stomp mode. Or if you typically play songs in a set order, you could set Up/Down Switches to "Presets", at which point a single press of Up or Down would instantly select the next or previous preset, without a preset queue."the Tonelabs [TLSE/LE] STILL eclipse even the Fractal Audio realm of realistic delivery of professionally simulated amplification by virtue of excellent amp modelling and ingenious 'dummy load' output compression... Although most of the Impulse Responses on both units suck, 40% of them fluked an excellent capture, which is why many professionals favour these units for live work and even recording today..."
It's been a long wait since namm.
The screen was awesome though - totally made it easy to navigate and get into. I have a brand new HX FX now but would trade scribble strips for a display like the LT and GO.
The LT is a very good proposition for £550ish used, not sure how I'd cope with it on a pub floor but then I gigged a Pedaltrain Jr rig worth about £1k for years and everything that was on it is still going strong? The LT wouldn't be much less manageable.
https://www.youtube.com/watch?v=_ZZsOeiKeTk
UK delivery dates keeps getting pushed back....looks like end of June at the moment, but I'm guessing supplies will likely be limited even when they do start filtering through. I'd still like to see some independent video reviews/comparisons with other mfx, and see feedback from users after the initial honeymoon period. But I will likely buy one as soon as these are available provided I can get a good offering e.g. I do like the Bax offering of 120 day trial period, free returns and 3 year warranty.
