I’m certain it will work with the Fluence pickups, and it even mentions being powered by the same battery in the description.
https://www.fishman.com/accessories-tuners/powerchip/
Use the Powerchip and dual output sockets approach.
The other simplified method described in the Powerbridge instructions is asking for trouble.
If you want a simple passive installation with just the Powerbridge then you do need separate outputs, but the real advantage of that is not needing a battery in the guitar, which isn't relevant if you're using Fluences anyway.
