SOLD 1979/1980 Park Lead 50 1x12 Combo
A rare beast, this amp sounds incredible. It's like a plexi with a master volume and reverb in a nice 1x12 combo format.
One of the very best amps ive had the pleasure of owning but unfortunately it's not getting much use so I'm letting it go.
I believe this is a re-badged Marshall 2144 in a 1x12 format.
The amp is in good condition for it's age. It appears to be all
original including the caps so it would probably benefit from a service.
The gain pot has a slight crackle but the rest are fine. The valves are
a mix of chinese 12ax7 and the el34s are old uk made ones. The reverb
tank is accutronics.
There is switchable reverb and boost(the amp comes with a modern
Marshall double switch). The speaker is a modern g12 heritage 30.
£625 delivered.
Rob
