Fender Princeton Custom Solid Timber Cabs and baffles
skippy76skippy76 Frets: 616
edited June 2020 in Amps £
Hi all,
Ive cleaned this thread up, just selling hand made Princeton Cabs here now (you can PM me if you’re after something different).
Cab 1 - Aged/“antique” finish solid pine
If you have a Princeton 65 or 68 Reissue then your chassis will drop straight in but removing the 4 bolts in the top ”straps”, side the chassis out and into the new cab, replace straps and 4 bolts.
Depending on what look you are going for you can bolt your baffle (with speaker attached) straight in with four/six screws.
Alternatively if you wanted a birch ply baffle in 10” or 12” I have a couple left over from my build.
Price for the cab ready to take the chassis and baffle is £100 (pm if you would like a new baffle as well)
SOLD  two stock original Fender cabs, the 65 Cab is in excellent condition £35 and the 68 is in great condition with three small holes where the tilt legs were located £30
Cheers
Toby
  • UnclePsychosisUnclePsychosis Frets: 12886
    Looks great. I've got two quick questions-
    1. Is that a posted price?
    2. Whats the weight like compared to the stock cab?
  • dallcorpdallcorp Frets: 139
    Pm sent
  • thecolourboxthecolourbox Frets: 9710
    Hi, would it be possible to ask for the dimensions, actually just the width, of the spacee available for the chassis in the original cabs? Thanks
    soundcloud.com/thecolourbox-1
  • osborne900osborne900 Frets: 18
    Pm’ed
  • cemskycemsky Frets: 1
    I will be interested. Please let me know the dimensions for the chassis and delivery cost. Cheers
  • skippy76skippy76 Frets: 616
    edited June 2020
    Evening all,
    PM’s replied to.
    The internal dims for the chassis are 471mm x 204mm, the stock cabs allow for tolerance and have a gap of a few mms either side, mine are the same.
    And the mounting holes are set using my PRRI 65 so will be a direct swap for other PRRIs.
    Postage will be around £15 UPS next day.
    I haven’t weighed them but they are lighter than the stock tolex’d cabs.
    Hope that helps
    Morning all,
    Stock cabs SPF
    Pine Cab still available.
    Cheers
    My walnut cab is nearly done so this one is no longer needed,
    Price drop to £120
    I managed to get a couple of new birch ply baffles done today, oxblood:
  • 4on64on6 Frets: 86
    Please excuse my ignorance... what does SPF mean??? I was after one of the stock cabs... died that mean they’ve gone? Regards
    edited June 2020
    Morning, SPF = Sold Pending Funds. They are now sold thanks
    Price drop to £100 for the pine cab for the weekend.
    Cheers
    Cab 2 - Poplar with Walnut Racing stripe - £100
    Hand built solid Poplar cabinet
    12” Princeton Birch Ply Baffle - £50
    Straight swap for the stock baffle and takes a 12 inch speaker. I have one in oxblood and one in wheat.
    Obviously with a speaker mounted you wont see the 12” circle of back lit grill cloth!
    The materials cost me around £30 so the other £20 just covers a bit of my build time, but I’m mainly doing these projects to stay busy while furloughed. They are not perfect but are are very good option for the price.
    If you’re looking for some real life feedback @JerkMoans has one of my pine cabs and baffles :)
  • harrisonlg81harrisonlg81 Frets: 229
    PM’d.
  • tone1tone1 Frets: 5143
    I’ve not even got a Princeton and I’m still tempted  =)
  • EmielEmiel Frets: 214
    PM'd!
    Morning all,
    I now have a new Princeton Stock black tolex cab up for grabs, £50
    Also the pine and poplar cabs are still available
    cheers
    Toby
  • BarnezyBarnezy Frets: 2177
    edited June 2020
    PM'd for the stock cab
    edited June 2020
    I'm trying to work out whether my 19" 1u rack modelling unit thing would fit in one of these, either the stock or the one with the racing stripe. What do you reckon? Will try and get mm dimensions of the thing later
    No worries, send me over the dims and we can work something out
  • JerkMoansJerkMoans Frets: 8792
    It's true!  And it's the mutt's nuts.
    Inactivist Lefty Lawyer
