Writing a song with science! Well theory.
I’m trying to get myself to a working understanding of theory.
My plan is to write a song based on theory.
The verse will be in Aminor, with the chorus in Cmaj (it’s relative major) to give a happier tone to the chorus.
I’ll pick a common 3 chord trick for the verse, and a 4 chord for the chorus.
Turn around will be In Aminor.
for the melody lines I’m going to pick up on the chord tones in each chord and the minor for the A, likewise for the C
  • So the verse is going to be on
    1-4-5 (Am,Dm,Em)
    and the turn around is
    2,5,1 bm7b5, Em,Am
    And we’ll try 1,6,4,5 for the Chorus so that’s C,Am,F,G
  • vizviz Frets: 10691
    edited June 2020
    You can always make the E a major chord (or a dominant 7th) if you fancy, because even though that doesn’t “fit” in Aeolian, it’s perfectly acceptable since Bach’s and Vivaldi’s time to do so. On the other hand you don’t have to! It’s nice as an Em too.
  • Interesting, I’d subconsciously done that in a couple of places Amin, Dmin, E seems more natural than the Emin
  • octatonicoctatonic Frets: 33793
    Try this for the turnaround
    Instead of going straight to the V chord, make that a ii V
    So:
    Am7 Dm7 Bm7b5 E alt
    Next, try a flat 5 substitution on the ii chord.
    Am7 Dm7 F7 E alt
    edited June 2020
    So:
    Am7 Dm7 Bm7b5 E alt
    Am7 Dm7 F7 E alt
    Lovely!
    Or you could sub the E alt, so
    Am7 Dm7 Bm7b5, Bbm7b5 (just slide down a semitone),
    then back to Am.
    to cheat and make it easy your B chord could be:  7 8 9 10 10 x
    and your Bb: 6 7 8 9 9 x
    Good call! ^^^
    Yep - it’s because giving the V chord a major 3rd (a G# in this case) provides what’s called a “leading note” to the i chord.
    That leading note helps make the melody stronger. It happens automatically in major keys but none of the minor modes have it, unless you deliberately allow it.
  • PolarityManPolarityMan Frets: 7284
    This is wrong
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • stratman3142stratman3142 Frets: 2196
    edited June 2020
    I view that as turning the Aeolian mode into the harmonic minor scale. I think of (and hear) the harmonic minor scale as the Aeolian mode but with a major 7th.
    It's not a competition.
    Correct.
    This is wrong
    What is wrong, @polarityman?
    The concept of writing a song from theory.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • RolandRoland Frets: 8701
    Whilst I can agree about writing from theory risking avoiding musical inspiration this is an exercise to help the OP
  • GrangousierGrangousier Frets: 2631
    I suspect, though I may be wrong, that to get the effect of modulating to a major, it would need to be A major, rather than just shifting modes - in particular, that shift from the C natural to the C sharp. Otherwise nothing would change, so you wouldn't notice a difference.
    Well both are possible. Shifting from minor to major with the same home note has one effect; shifting up a minor 3rd to the relative major has another. Both are often deployed.
    Ah. Yes I understand. Well, inspiration comes from the heart not the theory, but most great composers were pretty damn good at theory so I think it’s second nature to use it.
  • MusicwolfMusicwolf Frets: 3654
    edited June 2020
    I wouldn't normally write from theory (mainly because my theory is so poor) but I was doing some scales work the other day which lead me on to a chord sequence that I probably come across under normal circumstances and this triggered a brand new song - so yes, it has its uses.
    Of course the thing that made it a song rather than another 'idea' was the hook line.  Don't ask me where those come from - they just do.
  • The concept of writing a song from theory.
    Well we deconstruct them with theory... my aim is to see if I am understanding what I’m hearing by building up to a song with known sections.
    I hear about people saying to play jazz find the 251’s well if I can’t pull them out of a sequence how do I know that they are there.
    Why not create a song and include them and become conscious of what’s there?
    I don’t doubt it won’t be a modern classic :-) but it’s part of the learning journey.
    I am currently consciously incompetent at theory.
    I need to become consciously competent - at which point in expect to churn out the same basic noise at any other nit wit.
    Unconsciously being able to write a solo that follows the chords is where I’d like to be, not just blazing away in a blues box knowing I have no ‘bad’ notes but by definition also having no extra ‘good notes’
  • BradBrad Frets: 659
    Hmmm brilliant music has been created without the need for theory. Brilliant music has been created because of theory, and the opposite is true in both instances.
    @Lesgrandepotato keep at it if that’s something that you have a desire to improve on.
