Wtb Jecklin Disk (sorted, kinda..)
SpringywheelSpringywheel Frets: 942
edited June 2020 in Studio & Rec £
A bit of a long shot, but does anyone have a jecklin disk surplus?
Please don’t tell me to build one myself, I’m too lazy for that.
  • roman_subroman_sub Frets: 18
    edited June 2020
    If you are considering new, this one is good quality. https://www.canford.co.uk/Products/92-598_MB-OSS-Jecklin-disk-MICROPHONE
  • SpringywheelSpringywheel Frets: 942
    Yeah that’s the one I was looking at...just not sure I can justify spending that much.
    Yeah it’s pretty specialised. Good on choirs and organs... keep an eye on eBay, they sometimes come up there.
    edited June 2020
    I did a u turn in the end and decided to make my own D ....a few 12” vinyls glued together; a layer of cork + acoustic foam on either side, with a long dowel passing through the middle to hold the mics (I’m using tiny clip-on binaurals). I just need to wrap the whole thing in lambs fleece and attach a universal mic clip.
    edited June 2020
    Sounds like you are following the correct principles!
    If you are intending to stick close to the original research paper and intended design, you need to make sure the mic distances are roughly human ears width apart.
    in terms of mics themselves, ideally you want to be using omni’s with slight high frequency lift. IIRC he designed the system with DPA 4006s in mind (would have been B+K then!) Those are v pricy but cheaper variants exist. Just using neutral omni’s can sound a bit dull (and cardiods will end up sounding somewhat congested and roll off the bass)
    good luck!
