If you are intending to stick close to the original research paper and intended design, you need to make sure the mic distances are roughly human ears width apart.
in terms of mics themselves, ideally you want to be using omni’s with slight high frequency lift. IIRC he designed the system with DPA 4006s in mind (would have been B+K then!) Those are v pricy but cheaper variants exist. Just using neutral omni’s can sound a bit dull (and cardiods will end up sounding somewhat congested and roll off the bass)
good luck!
