It also didn't say if it came with the footswitch - that matters, because it's an almost unique type with one latching and one momentary switch. Not a well-designed amp.
I really liked the sound. Cool amp as long as you don't try to use it as a channel switcher. I might pull the trigger again one day...
I know it's anecdotal, but I never had any problems with mine, and I used to run it full chat for quite long periods. What are the issues with them?
Yes, I think Marshall made a booboo by allowing you to switch dynamic range from the footswitch, as that gave the impression that it was a channel switcher, when it wasn't.
I presume they are the same as in other versions? Like a crunchier G12M. I've still got a Vintage Modern cab full of them you're welcome to buy for cheaps!
Out of curiosity, what didn't you like about it?
It even extends to things like the power LED not having a reverse parallel diode so it often burns out - trivial in some ways, but just bad design. From a user point of view the Dynamic Range switching doesn’t work well, and the FX loop and reverb are poor... these aren’t rocket science to get right!
