GAS'ing for a new acoustic in 2021 - With a happy ending!
LestratcasterLestratcaster Frets: 1087
edited May 2021 in Acoustics
Hankering for a new acoustic guitar next year. Been running with my Takamine EG321c electro acoustic since 2011 which sounds good unplugged and decent plugged in. Back when I bought it though I didn't really pay much attention to acoustic wood, tone, etc.
Now I've been playing more due to the lockdown, giving online lessons, doing live streams/recording etc and have started to hear things that lack perhaps.
The 2 premium brands seem to be Martin and Taylor, so I'm wondering if I should get something from one of these two. The Martin D28 is way out of my budget, costs the same as my Kemper did! But I've seen the D-10e, the DX1e and another D model I can't remember the same of that are a bit more sensible and realistic in prices.
What puts me off about some electro acoustics is the pickup sound, horrible clicky metally boxy type sound. I believe Martin use the Fishman pickups that I have no experience of. I would like to it sound as nice plugged in as it does acoustically (i.e unplugged).
My playing style is mostly open chord and strumming as opposed to fingerstyle or lead soloing (although I do a bit).
I believe these guys use either Martin or Taylor and their playing matches my style:
The guy in the red cap looks like he's using a Taylor. (Its obviously been pre-recorded with nice mics and EQ'd I suspect)
In this clip the sound isn't as good as I believe they might be going DI:
Anyone on here own a Taylor or Martin acoustic? Would the D-10E/DX1 be a good upgrade? Or shall I look at other brands?
«1345
  • droflufdrofluf Frets: 3684
    I’ve owned a Taylor and now have a Martin - neither have pickups so I can’t speak for the plugged in sound but unplugged they, as brands, have distinct sounds. To my ears the Taylor sound is more brash and “in your face” with stronger trebles whereas the Martin is warmer and more rounded. Both are great brands but people seem to prefer one or the other.
    Obviously the normal advice is to try before you up but that’s not so easy these days...
  • Before you go chasing another guitar, you might like to try a range of stings. I used to use Martins exclusively. But following a thread here I bought others. The biggest revelation was fitting my PRS SE A40E with D'Addarios. I was gob smacked at how much better it sounds both unplugged and plugged in.
    At  least it's cheap!!!
  • It's also not as simple as 'a Taylor' or 'a Martin'. I have two Taylors – a 714 and a 322 – and they're completely different guitars. I'd wait until lockdown lifts (it won't be long now) and go to your nearest big dealer and play as many as you can. If you're buying a premium instrument, consider other quality brands too. Once you've decided what you want, buy it used and save £1,000.
  • Martin and Taylor tend to be at the higher end of the market price wise. They generally sound quite different when you compare similar models from each brand. As @drofluf says, Taylors are pretty bright, while Martins tend to be warmer. Obviously, different models have these characteristics to a greater or lesser degree. I was in a similar position to you a few years back and tried lots of models from both companies. Personally, I found the Taylors too bright, although I know that others are drawn to them for this very reason. I ended up getting a cedar/rosewood Furch Grand Auditorium. It's easily as well made as a Taylor or Martin, but was noticeably cheaper. It probably sits between the big two in terms of sound. It's a good all rounder for strumming, finger picking, lead type stuff. I've subsequently bought two Audens, a cedar/rosewood parlour and a spruce/rosewood dreadnought. I was actually looking at Martins when considering a dreadnought, but the Auden was on a par with Martins at twice the price. I wasn't so enamoured with the Auden dreadnought in cedar/rosewood, the spruce/rosewood version seemed more balanced to me. For what it's worth, I did try some very nice Takamine's too (sorry, I can't recall the models), so it might be worth trying different strings or having a different pickup system fitted to your current guitar.
    Hmm going by that I think a Martin would be better choice if I was to get one of the two. I've played one of my learner's Taylor electro acoustic but I can't remember what model it is. It was very nice to play though but was £1500 (or so he said)
    I use Elixir's and they are the best sounding strings I've used. Don't like D'addarios, they wear out too quickly and don't have that brightness.
    There's probably other brands I can look at that'll give me a similar sound for a lot less. My electro-acoustic was bought from GAK so I presume when this covid shit is over I can take a trip down there to have a good try out (I never buy guitars without trying them first)
    It'd be hard to find a 'bad' Martin guitar wouldn't it? Apparently even the DX models that are around £500 sound decent. I will admit I'm less knowledgeable on acoustic woods than electrics. Haven't heard of Auden so will check them out.
    I like the sound of the LR Baggs pickups so could get that installed in mine, it'd be cheaper and saves another guitar taking up more space! I only have 2 acoustics anyway haha.
  • I think that is a Koa Taylor that the guy on the right is playing. Has a really bright sound. I actually won a Fame Koa recently in a songwriting contest (sell for £900 new, solid Koa front back and sides) and it sounds similarly bright. I would never have bought the guitar as don’t know the brand but it sounds and plays incredible. Worth thinking about the woods and playing different models.
    Yeah a K24e or something? Apparently its custom built but they retail around £4k!
  • Andy79Andy79 Frets: 888
    I would go out of my way to avoid so called electro acoustics, a great gouge out of the side with electronics that will be out of date in no time. Get a std acoustic and add stuff afterwards
    Im probably Taylor’s biggest anti-fan. Just cannot get on with them. Cheap Martins are well out gunned by other makers but higher priced ones are tough to beat. Those new Epiphones look worth a look. Seek out something with maple back/sides to try. Great tonewood. One of my favourite guitars is maple/spruce
    Let us know body shape and budget and we can throw out suggestions
  • My advice would be do not get an electro-acoustic unless you're planning on spending £2-3K upwards. Below that sort of money, I've not personally played or heard anything that sounded worthwhile as an unplugged instrument when compared to the same outlay for an equivalent guitar but without anything electric in it. I wouldn't trust any online demo for an acoustic guitar, either. It's how it sounds in a room with you playing it that really tells you if you'd like to own the guitar yourself. And (if you can) having someone else play it so you can sit away from the guitar and hear how it really sounds.
    If you're looking to spend less than £2k on a new guitar I'd not bother with Martin or Taylor. Try L'Arrivee and Furch. Your money will buy you much nicer tone using wood that will develop over time. For me, less expensive Taylors are aimed at people playing acoustics in the context of a rock band. Not much subtlety in the sound, but in the context it doesn't matter. Less expensive Martins are built down to a price for people who just want that name on the headstock. Play fine, sound poor.
    Find a nice guitar that is 100% acoustic and just add a K&K pickup if you want to amplify it.
  • jellyrolljellyroll Frets: 3073
    Agree with Bigdipper. Martin standard series (£2.5k+ new) and up are great but their cheaper models don’t shine for me. For less money, I would direct you to Eastman. Furch are also well thought off, though I have no experience.
  • You have Kemper ( brilliant but not cheap ) a s/h D28 at the same price as a new Kemper - a classic acoustic for life at the price of a depreciating piece of kit ? Worth thinking about. That being said there are some wonderful acoustics out there without Martin or Taylor on the headstock.
    Haven't got much knowledge on body shapes and what not, my EG321c is a single cut but I don't really need access to the higher frets.
    Yeah I guess I've fallen into the trap of "It has to be a Martin for it be a good acoustic", when there are other brands out there that can get a similar (if not better) sound.
    I checked out a few Furch models and they do sound very nice, and depending which one it is slightly more affordable.
    I mentioned the LR Baggs pickups which I like so I could possibly add one of those but I believe K&K sound more natural.
    Eastman cropped up a few times but I haven't got any experience of what's good/specific models etc.
    The only way I could pick up a D28 is to get it on finance perhaps haha. Would be too scared to travel with the thing or leave it unattended though.
    But if I'm going to spend a decent amount I obviously wanna make sure its the right one for me and my playing style.
    So what is your playing style?
  • LestratcasterLestratcaster Frets: 1087
    edited December 2020
    Similar to those guys in the videos above. Chords/strumming with a pick. I do a little fingerstyle and some picking stuff but mostly chords I'd say. I like to fiddle with alternate tunings too, DADGAD and those open ones.
