I really wouldn't worry about it
If anything I think it sounds better than when I used to keep it in the case. The only issue at all is that I have to dust it sometimes...
I wouldn't have had the space to do it on guitar stands and I'd also have been more worried about accidental damage. Wall hanging has kept them safe to date.
I have a humidity and temperature monitor in the room and have never had an issue with changing neck relief. I obviously keep them away from sunlight.
I agree with ICBM about the dusting - and the constant visible reminder for my wife to ask me if I really need that many guitars.
The Hercules supports mounted directly into a solid (in my case brick) wall feel very secure.
Just explain to her that 13 is unlucky and bad things might happen. You need another one to make it a nice, safe 14. Better make it a couple more, just in case.
(You next unlucky number is 87, so you should be OK for a while yet.)
Edited to appease Mrs M!
I really like them on the wall - better than art and makes them very accessible.
I found these, but they are expensive:
https://audinni.com/products/guitar-cabinet
(£1750 + delivery for 4 guitars)
