but any 80/20 should give you ‘bright’ sound - but once they go dull they go really dull!
For bright *low end* (ie twang) and punchy mids, phosphor bronze is much better.
Exactly.
Most acoustics are strung with phosphor bronze - that's an alloy of copper and tin with a little phosphorus added. Brass is an alloy of copper and zinc, typically 80% copper, 20% zinc. (You will often see it advertised as "80/20 bronze", which is just wrong - refer to any chemistry textbook.) Brass strings will bring you a good dose of extra zing, not just for the higher strings but particularly for the bass strings, where you will notice their extra snap and definition. The downside is that this may be too much of a good thing. Also, brass strings typically last maybe half as long as phosphor bronze.
Really, the only sensible thing to do is try a set. Pick whichever brand you prefer, it won't mater al that much.
These are as far as I can remember the only round core phosphor bronze acoustic strings I've used, and to me they do sound and feel noticeably different to all the other types I've tried, which is most or all of the major brands (working in music shops for years) - which I don't hear vast differences between, although I do generally find the D'Adds the most punchy.
80/20 is definitely the brightest string we make for acoustic (and pretty much the brightest alloy overall). However as the OP asked for bright in the low end and punchy mids, Phosphor Bronze is probably about the best choice. That or you could also try Nickel Bronze which is an interesting alternative and has even less of a scoop in the middle.
____________________
www.adamironside.com
www.youtube.com/Adji87
