Storing used strings
Alright wondering if this is madness or not.
Put a set of low tensions on my classical but thinking of changing to titanium strings for brightness, anyone store strings that aren't that old?
  • ICBMICBM Frets: 71960
    I keep strings if they're re-usable. I mostly end up using them if I break one while working on a guitar, it saves replacing the whole set or having one string much brighter-sounding than the others.
  • GTCGTC Frets: 261
    Like ICBM, if they are in good condition, might have a future use and of a long enough usable length then I'll keep them. They might come in useful for a future experiment or in an emergency.
    You have to be a bit more careful in removing though.
    Personally, I'm a great fan of the D'Addario Titanium nylon trebles. I find them a little warmer than carbons whilst still being nice and bright.
  • fretmeisterfretmeister Frets: 23955
    I keep mine in a poster tube with a couple of packs of silica gel in there. I use a velcro cable tie at both ends to keep them together as a set.
  • RolandRoland Frets: 8591
    I keep old strings too. It started as a hang over from the days when I couldn't easily afford a new set, and needed something to fall back on if a string snapped. More recently I've found a use old strings when setting up a guitar, frequently de-tuning to adjust the truss rod or saddle then re-tuning to check. Unlike @fretmeister I'm not that concerned about preservation. I coil each set up, and hang a few coils from a hook in the workshop.
  • ZonularZonular Frets: 62
    Changing from the pro Arte low tensions to the titanium trebles is actually my plan. I just need to mark the strings
  • Andy79Andy79 Frets: 888
    Can’t be arsed with it, straight into the scrap
  • TanninTannin Frets: 5268
    It is probably easier with classical strings. I always keep a few sets of used-but-playable strings around for just-in-case, but often find that they snap when I try to re-fit them.
    I do find used (steel) strings very useful around the house for a variety of tasks. My favourite use is feeding the quolls - I drill a hole in a bit of wallaby tail and use an old guitar string to attach it to a short post. The quolls love chewing on it (of course - what wild animal doesn't love a free feed?) and because they can't run away with it, each one of them gets a bit of a turn. After dinner at night I turn an outside light on and sit by the window playing guitar and watching their antics. In the morning, there is just a bone on the end of the string.
  • LastMantraLastMantra Frets: 3822
    I've not changed strings for years so when I do they'll be going in the bin.
