Having just moved house, I've commandeered the larger of the 2 spare bedrooms which affords me more space than I had in our old apartment. We essentially had no furniture.
To that end I've bought a small studio desk from Thomann, and a standard steel frame table to act as work bench, with some plastic storage drawers underneath in addition to the steel shelving and guitar rack I already own. A futon will go in the corner to the left of the window so that it can occasionally be used as a 2nd guest room and so that I have a sofa.
The room is about 3.5m x 3m although feels bigger.
Now I'm in the process of unpacking everything.
I turned to the idea of bigger monitors thinking HS7's or LP6's to move up from my iloud Micros, so searched threads here for ideas and the topic of room treatment comes up over and over... Now I've no idea where to start. Do I NEED to treat the room?
Would I be better off with a set of decent headphones for mixing if I don't Want to go down what seems a rabbit hole of positioning/placement of pads and bass traps?
I want some AD/DA expansion to accommodate more dedicated inputs too, so maybe I should go with that and headphones?
Ultimately I want to improve my mixing, EQing a bit up from what I managed in my old apartment.
Really not sure what my options are. Pics of the new room vs old room below
2x2 timber, 50mm rock wool, hessian fabric.
I made mine 1200 x 600 .
https://twitter.com/spark240
Reddit r/newmusicreview
https://www.thefretboard.co.uk/discussion/192149/acoustic-panels#latest
If its for your own enjoyment, and maybe some demo material for a bands promo stuff, you can get by without room treatment AND still use monitors. The trick there is to spend tome and get to know the speaker and the room - reference any mix'd material on as many other systems and spaces as you can. You will get to know where you are over or under mixing from that, and will compensate. A decent (not top tier but decent) pair of headphones helps to confirm low end and phases issues.
I do just that in a slightly smaller room (being 1.8m x 4.8m), and I have a sub as well - not for mixing, as I turn it off for that but for playback/enjoyment etc - and then check the mix on headphones (both HD650s and a pair of AKG 702s). I do use quality speakers (Neumann KH120s and KH750 sub) that has had room calibration. That has fixed most phase issues, but it wont get rid of the 110hz low freq hole from wave reflections (and a less prominent one at 220hz, which is the same wave problem) . I know its there, and I mix accordingly, then check on the headphones for the low end on the phones, then I reference it on my downstairs Hifi, in the car and on my phone (using normal phone headphones). I dont need to do too much usually after checking the 3 systems as "knowing" how my room/speakers translates and the headphone check normally gets decent enough results.
Having said that - and level above that will need some treatment - and treatment is better than no treatment even for the use Ive outlined. i would have corner traps IF I could, but my room is crammed to the ceiling on all the walls I can use.
Ill end where I started, it totally depends what you want from your mixing, what its for, what level your after. Im nowhere near Octatonic league for instance, so what he uses (equipment, space, treatment) while being great, just isnt achievable for me, and nor do I need it to be.
FWIW I mix most of my stuff on cans ...I have HS7 monitors and I like them but I dont rely on them solely for mixing.
As per the last couple of posts - do not waste your money on foam products from ebay.
The way that absorbers work is that they convert the Kinetic Energy of the moving air molecules into Thermal Energy (the absorbers heat up by minute amounts). To do this you need dense mineral wool (Rockwool RW3 is 60kgm-3) and it is most effective at a position where the air is moving fastest, that means ¼ wavelength away from a wall. Wavelength is inversely proportional to frequency (lowest notes have the longest wavelength) so, in order to tame the bass, you need very thick absorbers / spaced far from the wall.
A frequency of 250Hz would have a wavelength of 2.28m which means that ¼ wavelength is 570mm (2 foot). A typical DIY absorber might be 100mm Rockwool spaced 100mm from the wall (200mm total). That’s still too skinny to really tame the low end, hence the need to check on headphones, but it still improves things considerably. A couple of inches of foam is going to do bugger all. In fact, because it will kill the high frequencies without toughing the lows / mids, it will probably make the room sound ‘boxy’.
RW5 (100kgm-3) is probably of benefit in a sound 'proofing' application. Readers – please note that sound proofing and acoustic treatment are different things, even if some of the materials are the same. Acoustic panels will not do anything to prevent sound from escaping from the room. For absorbers there is very little difference in the behaviour as you need the wave to penetrate the panel in order to be absorbed.
Mineral wool is effectively sold by weight, so it’s really a matter of value for money. RW3 is stiff enough to be self-supporting when used in panels.
