But for strings, something like Silk and Steels, or Newtone Heritage make a difference for the fingers as well.
The point about applying too much pressure on the strings could be part of my problem, it's instinctive though and requires a certain amount of self discpline to stop doing it.
I'll check out the Newtones.
Also check that the nut and relief are right otherwise your first position chords will feel very stiff. On acoustics because the action is higher I only have a tiny bit of relief, like an pl10 string width or less. (Holding down B string at nut and highest fret and checking gap between bottom of string and top of 8th fret)
EB Slinky 9's as I recall
Playing it again, I've concluded it is not my technique or the guitars action that it the problem - it is the strings.
I bought it as new condition so I've got to assume that they were the ones fitted at the Gibson, Montana factory. They sound fine - but they feel nasty. Perhaps masochism is part of the Gibson journey.
