Hi,
Just bought an old 80's Bass 12 off fleabay - really grubby and looked like it hadn't been used in ages. When I switch it on there is a loud humming sound. Pots very crackly, So I have stripped it down, given the cabinet a good going over, given the board a visual inspection to see if there is anything black and charred hanging off it - all looks in order. Pots have had a good drenching with contact cleaner to dislodge any grime.
A more detailed description of the hum:
Amp switched on, no lead attached. volume and gain at zero, amp humming through speaker. Gradually rotate the gain control, the hum quiettens down (but still there), then goes back up to the original volume with gain at 10.
With guitar attached, same thing happens but with the gain at zero there is a sound like shortwave radio interference.
Does anyone have any ideas what it might be? It's a pretty basic looking board, so rather than taking it to an amp tech, I'm wondering if I can sort any component replacement myself to save a few quid (usual disclaimer about high voltages/ possible death etc.) At a guess, I wonder if it needs the caps replacing - it's over 30 years old, so that may be a possibility. While I'm at it I may replace the pots as the previous owner has squeezed the split shaft on each of them and in some cases slightly bent the spindle.
I appreciate that it is difficult to diagnose a problem without seeing the amp, but it sounds like it may be something that is relatively easy to fix. Any suggestions would be much appreciated.
First things first. Have you inspected inside the mains plug?
Check the mains earth before you do anything else as Funkfingers said - not least for safety.
These are excellent little amps and well worth sorting out. They're a bit cleaner and chunkier-sounding than the Lead 12 and take pedals very well. It's possible the caps could need replacing, but don't assume so until you've found the source of the problem.
If you're *very* careful you can often straighten out the bent pot splines, but it's extremely easy to bend them too far and snap them off if you go even slightly beyond the original position. I do it by forcing a tapering knife blade into the gap, that seems to be controlled enough to open them out with the least risk.
I did type all that out first since it's the usual answer to this problem, then scrubbed it since you said gain!
There is some anecdotal evidence that physically smaller caps don't have quite the same 'heft' to the tone, especially in big bass amps - this may be real, and if so is due to what's called 'equivalent series resistance' which is generally higher in smaller caps - but I doubt it will make a difference in such a relatively low-powered amp.
You don't need to glue them as long as they're tight down to the board and can't vibrate - it's common to run a bead of hot-melt glue along the board directly under the cap before you push it down, if you're worried about it. In fact, you probably don't even need that - just pull the leads through tightly and kink them under the board before soldering.
I always inspect inside the mains plug before I ever plug an unknown amp in for the first time - always! I've seen some really scary stuff over the years, including things that could at an outside chance kill you if there's also a missing earth connection.
(The real worry about dodgy wiring in venues and rehearsal rooms is that your own gear can be in perfect order and properly earthed, and it still won't save you from a fault in a PA or the room wiring if you touch the mic and your guitar at the same time.)
There are two other filter caps which could also be the cause, C2 and C6 - they're for the lower-voltage rails for the preamp.
C2 and C6 should be 22uF 25V electrolytics.
On the 20W schematic they're labelled as C15 and C16, but in either case they should be smaller versions of the ones you've changed already. It looks like they may be at the top right of your pic.
Apart from those there should be no other components that will have degraded with age.
Also just spotted that from memory, TR4 is meant to be heatshrinked to the heatsink leg next to it - that's why it's sited there - to provide thermal feedback for the power amp.
It doesn't matter, as long as they can't vibrate about. Stick them to the board with a bit of hot glue.
