Check the continuity of the mains cable earth wire. It’s not likely, but just possible, that it’s broken inside. (If so it will be at the cable clamp
on the chassis.)
The pop when turning off is normal, but it could be worse if the earth is missing as well.
Eqd Speaker Cranker clone
Not sure if it is relevant, but there is a space for C11 next to R17, but there isn't a component installed
R.
Pots are usually quite wide-tolerance (typically 20%), and won't make any difference. The only one that doesn't look quite right is R22, but even then it's unlikely such a small discrepancy could be a problem.
