\What cabs are you running?
Running a Zilla 1x12 and 2x12 at the mo but given that I'm this deep in the rabbit hole I'm going to look out for some Boogie 1x12's
Si
You're going to need a bigger rack box if you get the Mark L - I make that 10U already. 12U will give you a spare slot, which is always dangerous .
https://www.thefretboard.co.uk/discussion/210503/fs-dyno-my-piano-t-shirt-tri-stereo-chorus-rack-fans#latest
@Schmo - Running a Morningstar MC8 for patch change/CC control and will be using Morningstar RL5 (s) to switch the inputs in and out for the SPX, PCM 70 & 81 and anything else that appears. I'm trying to find a midi controlled latching switch for the Studio Pre (Suhr used to do one so hunting at the mo). I've looked at your shirt a few times actually
The TSC is the biggest challenge. Speaking to Italo De Angelis (rack FX guru) you can get close with a H3000 (or better) or another PCM81 but nothing can replicate the TSC sound exactly. I would really like a TERC but part of my own brief was not to buy anything I'm going to take a massive financial bath on and a TERC would be given the total cost to get one from the States. That said an H series Eventide or Orville isn't exactly cheap but way more flexible than the TERC.. Will make my mind up later on this.
I'll update the thread as the build progresses.
Si
I have the RJM & CAE for my looper/mixer...and a TERC too, no compromises LOL !
Italo does great work no doubt, but as you say there is no substitute for a TERC no matter what anyone says...best of luck on completing the rig.
Regards,
Graeme
Managed to get a quick setup with the SPX and PCM81 in parallel and it sounds pretty awesome.
Couple more bits to get hold off and we're ready to go..
It's a cracking setup you've got going on there.
I had a Tri-axis/ Stereo 2:90 rack setup with a TC G-force and Voodoo labs GCX/GCP for control and effects years ago.
I really wish I had held on to it! Especially the Mesa amps. With one or two exceptions not much has come close to the tone or versatility I had with that rig.
https://www.thefretboard.co.uk/discussion/207596/bolters
Next do a 90s one with a Quadraverb and an Art with the pink squiggles on it.
That wouldn't be out of place on a stage with Lukather, Landau or Dann Huff.
What's left to get? An ADA MP1? An Eventide Harmoniser?
Er no.. enough is enough and this is an expensive wormhole I'd like to get back to some playing...
I've got it running as a stereo rig..
Si
