Creating drum tracks for songs
Hello, Fretboard!
It is a ridiculously long time since I've been around here, so hi, and help!!
My age old problem when songwriting is how to create quick and easy drum tracks.  Ideally, I'd like something physical so that I'm not having to twit around with tiny little squares and mouse clicks (it takes an age, my hands get sore and I do not have the patience/time).  I'm wondering if a cheap drum machine would help me - I have no real clue about drums beyond the basic kick-snare-hi-hat rhythm - so this may be more of a hindrance than a speedy alternative.
Previously I have used EZ drummer with some success, but it still takes an age and there's lots of mouse work, so just wondering if there's a more suitable alternative.....in this modern world.
Any guidance greatly appreciated. Max budget £150 ish.
Cheers,
Clare
  • poopotpoopot Frets: 9098
    Are you on Mac?
  • mrkbmrkb Frets: 6637
    If you still have an ezdrummer licence, then adding a cheap midi input like a akai lpd8 would get around the mouse click issue to create beats. I doubt you’d get something that sounds as good for £150.
    Karma......
    Ebay mark7777_1
  • poopot said:
    Are you on Mac?
    No Windows PC
    Thank you, that sounds like a good work around.
  • I use easy drummer 2, but I build everything with the included loops.
    I never used the original EZD so I don’t know how different 2 is, but I can find something I like for almost everything.
    I did buy a funk and jazz expansion for more old school drum sounds, but the loops are the same, just different tunes.
    It is actually EZD2, I think, and it is great, it's just the fiddling around. And I was struggling to get it to work properly on the laptop, although I think I've sorted it. I just hoped for a more arthritic hands friendly input method
    edited September 2021
    In that case something like that Akai would be ideal - just set a pad up for kick, snare,etc and tap when needed. There are lots of similar devices with various extra features - just find one that suits your workflow. Also check out teh additional midi packs (they often sell specific ones at £9, but currently all are 20% off). Use the "tap to find" capability to find beats that are similar to what you want - if you enable the "show webshop midi" option it will show you (and allow you to briefly listen to) what midi packs have similar beats for ones you havent purchased..
    Best MIDI Pad Controllers - 2021 [Top Picks]| Audio Assemble
    LPD8 MIDI Drum Pads | Akai Pro
    Karma......
    Ebay mark7777_1
    Thank you very much, mrkb, that's a great help.  Happy Sunday.
  • SnapSnap Frets: 6256
    eyup stranger!
    Have a look at the Novation Launchkey Mini mkIII - its about 90 quid. very good value, has a 25key board plus 16 pads to control midi. I use it for drums and it's dead easy. Plus, it has a load of other neat controls that are useful. Gets universal good reviews. Well built too. Bargain!
  • FezFez Frets: 499
    I have a small midi keyboard that has some pads but generally I use midi packs you have to look out for the offers. The midi loops are easy to hack about to get what you want.
    Don't touch that dial.
  • personalnadirpersonalnadir Frets: 354
    I use an Electron: Cycles. Takes a bit of learning, but super easy to use after that. It does all sound like a drum machine as opposed to drum samples, but I prefer that at the moment
  • I'm not a big fan of playing in drums on finger pads tbh. For me it's slower than mousing it in by the time you clean it up. Admittedly I'm pretty fast at mousing in though but I suppose my main point is that it doesn't actually eliminate the need to use the mouse so I wonder if it might be better to grab a decent quality midi pack for the genre you're interested in and just drag in loops? Especially if your music isn't really heavily focused on drum / guitar interplay.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • JalapenoJalapeno Frets: 6378
    Didn't Toontracks (or someone else) have a program that "listened" to guitar playing and created drum tracks for you ?
    Feedback
  • I wish I could do this!
  • If you are trying to simulate the playing of a human drummer, remember that this lifeform only has four limbs.
    Unless you expect a drummer to headbutt the cymbals, drum parts should be four note polyphonic. Cymbals and gongs can sustain a fair while. The rest of the kit can not.
    Check out the DVD Neil Peart: Taking Center Stage. A master class in what is physically possible on a drum kit (or three!).
    Be seeing you.
    Rick Allen!
  • p90foolp90fool Frets: 31368
    Second hand Beat Buddy? I've never used one, but a couple of technophobic singer songwriter friends of mine love theirs.
  • I bought a large bag of loops and use them as a starting point:
    https://groovemonkee.com/products/mega-pack
    This is getting a bit off topic but while this is true I don't think its the most important thing to stick slavishly to. If you forget to remove a hi-hat hit when you program a crash and snare hit no one is really going to notice. I'd say instead the absolutely key thing to making programmed drums sound better is to set the velocity on the hi-hat / ride / whatever is doing the pulse. Drummers play in note grouping and setting those accents makes sooo much difference.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Youtube has some drum tracks (sometimes up to 10 minutes long), with varying styles and categorised by bpm.  if it is a case of getting a song going, and I don't want to be faffing, I will go to a youtubetoWAV site, download the WAV and stick it in a track on reaper.  (sometimes you may have to trim the start to get the wav to line up with the bars).
    Then at leisure (and when in the mood) you can go back and program or play a new drum track.
