Hopefully an easy one to solve for someone with more sense than me...
In really basic terms, I run Reaper on a mac mini, and obviously the audio comes out of the two sets ouf focusrite outputs on the rear. I can then run one of these pairs of outputs into a Boss RC-505.
I also have a sampler (Blackbox 1010) currently going into the rear l+r inputs at the back of the focusrite.
My hope was that by setting it up this way, I could use the sampler to send audio via the focusrite to the 505 too, without needing Reaper running, but it doesn't work. I can only get sound from the sampler when I open Reaper, arm a track with those l+r inputs and do it that way.
Am I missing something, or is it not designed to do what I want it to do?
The aim is that whether I use Reaper, or the sampler, or both, the audio will always come out of the 505.
My workaround is of course that I just send the sampler direct to an input on the 505, but sometimes I'll want to record from the sampler to Reaper, and it would be good if I don't have to switch any cabling around.
Is there a smarter way to do this?
Thanks as always!
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
