Thinking about making some changes to this one. Old-timers will recognise it, I'm sure, and I know a good handful here have played it - it's a custom no-hole thinline in ash, currently with TV Jones Classics (iirc a + in the bridge) and a 25" scale neck.
It's been off my radar for too long so I want to make some changes that'll get it working for me.
First is pickups. I don't want to route anything, so that means I'm looking at options in a tron-sized format. Top of the list is TV T-Armonds, or possibly their P90. If anything I'd like a bit ore chime than the Classics give me, which leans me towards the Dynasonic-alikes.
(EDIT: Actually no, first is pickguard, because the original pale-mint has gone really creamy and I don't like it, so I'll be getting a black one.)
Second is a possible change of bridge. I've been thinking about a Bigsby on this for years but I'm slightly nervous to drill it, for obvious reasons. But I do love a Bigsby and I think it would suit this very well. But I'm also interested in palm benders if I could get one that fits direct to the bridge without drilling. That would also free up the bridge for a Thinline build that's ongoing... Vibramate isn't an easy option here as they only make one model for the Strat hardtail mounting, which is 1) hard to find and 2) fugly. If I liked it then in the long run I'd be happy to do it properly and mod for a
@Tuffset bridge but I don't really want to go there without at least checking first...
Lastly is the neck. The choice of scale length felt like a good idea at the time, but now feels like a compromise between the Gibson & Fender standards and means it always feels weird. As I always use 10s on Gibsons and 9s on Fender types this ends up either too stiff with 10s or too floppy with 9s. So I wanna try my existing favourite Tele neck on here and if that works I'll get another one to the same spec.
Any recommendations or thoughts on the above?
If the former then go for a standard Tele neck, if the latter go for a short scale (Gretsch are usually 24.6", though 24.75" will be much easier to source and the difference likely imperceptible)
Is the binding cream? From the photos it looks like the current pickguard matches it quite well, I think it looks very smart as is
It has a set of gold Setzers on it currently but I still have the T-Armonds. I am toying with the idea of selling the body too...
Try 9.5 strings before ditching the neck
Instagram
That Vibramate won't fit as I have a Strat hardtail, which has different holes vs a cut-off Tele. Unless the string-through holes would still work and I could redrill the mounting holes.... Would need to do some maths
Not sure about the chrome vs nickel on the pickups. Is there a way to tell? They both look similar to me until the nickel starts to age.
*edit* 95% sure I'd have used something like this:
I should probably try and source the ugly vibramate as a proof of concept first…
I'm ok with a B5 on a Tele anyway
