Hey guys, maybe a bit of a wormhole question as this will all likely depend on a lot of factors (guitars, pickups, pedals, speakers)
Single coils, Kingsley Page or OD block for added drive, into an SD170. Various cabs/speakers at home/practise space, but all very similar results
Currently running the Matchless amp
block in my HX Stomp, and found the same/similar issue with the Vox and Matchless amps on the QC.
Clean/sparkly/edge of breakup they sound great - but anytime I turn up the gain or try to boost with an OD, I get a really horrible, flubby sound on the lower strings when playing chords. Maybe not the best description, but I guess it’s kinda like overly compressed and for want of a better expression “the amp is collapsing”.
I’m not even talking about large amounts of gain. Just over the edge of breakup with a nice low to medium gain overdrive.
I’ve tried reducing the bass on the amp block while increasing the drive but it’s not really helping the overall tone. Any bottom end is then gone.
Anyone else had similar issues, and any suggestions on how to get around this? Something else/obvious in my setup that I should look at?
Anything hidden away in the menu’s of the Stomp I could try changing?
At the point where I’m thinking of ditching this setup and lugging my amp back to gigs
https://www.instagram.com/insta.guitarstuff/
Currently for sale:
Kemper profiler
Gibson Les Paul R9
I’m talking minuscule amounts of gain, and I’ve no blocks left for a treble boost so I need to figure it out within the current blocks
