Well I never
FezFez Frets: 827
in FX
I never really got the hype about Klons but I had an Andertons voucher and the Behringer Zentara is currently on offer so I got one.
Tried it with the Marshall origin 20 and it's fantastic on it's Jack Jones so now I have to see what stacks best with it.
What do you stack with your Klon types/klones?
  • NeilybobNeilybob Frets: 1983
    edited May 6
    Nice.  Are you using it as a clean boost or an overdrive?
    I stack mine with a blue breaker style pedal.
    Check out Chris Buck's video where he shares klon settings from famous players at 5:20
    flanging_fed “
  • Winny_PoohWinny_Pooh Frets: 9516
    It's great into amps with a scooped Fender blackface tonestack as it's otherwise very nasal.
  • jackiojackio Frets: 541
    With a hotcake, and sometime with a shredmaster. The latter stacking is very good
  • FezFez Frets: 827
    Thanks for the link I will have a watch.
    Not decided how I will use it yet, got some experimentation to do.
  • FezFez Frets: 827
    Interesting as I was also looking at the Marshall reissues, would probably go for the Guvnor but out of stock at the moment at Andertons.
    Well worth a try @Fez ;
  • RevolutionsRevolutions Frets: 4684
    It stacks well with pretty much any drive pedal I've used tbh.
  • FezFez Frets: 827
    So far I have tried:
    Tube screamer mini after.
    Boss Sd1 before
    Ds1 after
    Dod screaming blues after.
    All work well .
    Tonight I will try the Thorpies
    I must dig out the BYOC pedals I built and try them.
  • redwedgeredwedge Frets: 97
    I've found my klon style pedal goes excellently with:
    True North Tweed Drive
    Fulltone Fulldrive 3
    EQD Special Cranker
    BOSS BD Waza
    edited May 7
    It's great into fuzz too. I set it about like this for whatever, the Shredmaster in particular likes this:
    Gain 10pm
    Treble 1am
    Volume 11-1pm
    It works as a straight boost into the next OD/District, but a bit of its own gain really gives a lovely effect, some brightness and a smooth sizzle, if that exists in your ear-brain descriptions
  • FezFez Frets: 827
    edited May 7
    Gain 10pm
    Treble 1am
    Volume 11-1pm
    I will try the Zentara into the fall out cloud.
  • FezFez Frets: 827
    So the Zentara works great into the Peacekeeper and Gunshot, pretty good into the Fallout cloud but I prefer the peacekeeper after the FC a mini spark works well after FC too.
    Zentara after Thorpies you need to be careful with settings as you can get a case of flub out.
    Favourite was into the Peacekeeper.
    The surprise was when I dug out the BYOC British overdrive (Bluesbreaker I guess) and the Distortion + again the Zentara driving into the others was best. I could even have all 3 on which is more gain stages than I would normally use but sounded great. The Brit was the best of the 2 for me.
  • daveyhdaveyh Frets: 765
    I’m using a Wampler Belle into a Tumnus if I’m using a SC guitar, with humbuckers I’m using a treble booster into it.
  • guyinlyonguyinlyon Frets: 647
    edited May 9
    guyinlyon said:
    It still surprises me how amazing the Digitech Bad Monkey sounds.
    I literally had my Les Paul>Bad Monkey>Tweed amp and I was getting clean Marshall tones and it reminded me of tone from Ain't It Fun by Guns n Roses.
    flanging_fed “
  • FezFez Frets: 827
    Tried the Zentara into my Loudpedal last night. Clean channel yuch but that is the same as every drive pedal I have tried with it. However into the drive channel loads better and it makes the boost on the Loudpedal  work great too.
    Next up into Tonex one.
  • FezFez Frets: 827
    Zentara into tonex1 with a cleanish jcm800 capture loaded yup could gig with that.
