Harley Benton PB-50 '51 P bass
5redlights5redlights Frets: 317
edited February 2015 in Making & Modding
Got this lovely little thing the other week from the wife as a birthday present....
Overall, very impressed for the money. It has the general feel of any other cheaper level guitar/bass, but is much cheaper.
The body is very good, nice feel and finish, some nice grain coming through, all of the hardware is relatively neat and wobble free. Controls are solid and work well, if a little "on/off", but I'm not surprised and didn't think these would be much good anyway. The pickguard is a bit roughly cut, but again nothing too bad and this may or may not end up going. The bridge and tuners are surprisingly quite good for the price, and I thought these would be essentially useless and clearly where money had been saved. These will probably stay until they start to fall apart. Might put brass saddles on sooner, actually. Bridge is going to have a cover over it, so not too fussed about having a modern looking bridge on it for now.
The neck has a nice smooth satin finish and there aren't any sharp fret ends, although a few frets are higher than others. The maple is quite pale, and there's a very clear difference in colour between the fretboard piece of wood and the rest of the neck, which is noticeable and a bit unsightly. This neck is one of the main areas where the cheap roots of the bass show slightly. I think this is actually their cheapest maple necked bass by around £30, so I imagine the other options have nicer wood in the necks. The feel and fit of the neck is however very good, so it's not really a craftmanship issue.
The most interesting thing about this bass, well maybe not in the grand scheme of things, is the fact that it's a wilkinson pickup. I may be wrong, but I'm not aware of any other wilkinson linked guitars (i.e. Vintage) having a '51 style single coil p bass pickup, which means this is the only bass you can buy it with. At least at the moment, until Vintage release a '51 P bass copy.
Soundwise it does what it's meant to do. Not the most characterful pickup, does solid rock/pop and quite good for punk sounds. Bassier than I thought it would be, but definitely happiest with lower mids. Seymour Duncan do a range of good single coil p bass pickups, so I'll stick one of those in at some point.
Modding plan:
  • Change over electronics - CTS pots etc
  • sort out frets/fret dress
  • cut headstock into '51 tele bass shape
  • sand headstock and fit 50's decal
  • Vintage gloss tint for neck
  • cut and fit white pearloid scratchplate
  • fit bridge cover, maybe pickup cover too
  • change nut
Effectively, it's working on the neck and the guts. The body of the bass is actually very nice, so I don't want to touch that. There's a guy on youtube who reliced his HB 51 bass, but I'd rather get this looking nice and shiny. Not much modding really, but just focusing on trying to create a good looking '51 style bass.
May take a while to start work as I'm waiting for parts, but will update as I get on.
  • Sounding good, your plans. Generally the Wilkinson Pups are pretty good and it's what I went with for my HB tele 30. All the best with your mods. Will be watching with interest.
  • 5redlights5redlights Frets: 317
    edited March 2015
    Right, finally got some time to work on this recently. After playing about with the bass a bit, I decided to swap the bridge out asap, as I was getting a bit of buzz from the stock one, so that's gone and replaced for a Wilko with brass saddles. With some adjusting the pickup's sound has improved immensely, so far happier with the pup than I was.
    I also changed my mind about fitting a decal. Love the 50's fender logo, but just didn't feel right.
    First work was to get started on some fret leveling. A few people have commented on the standard of the bodies being a lottery, and have to say this one seems pretty good. Wood pattern on the surface seems to match the one in the pocket, so don't think it's a veneer. image
    Got the headstock sanded ready to be cut down to a '51 tele shape, which will be this weekend...
    And fret's masked up and ready to go. I'm taking my time with this, as haven't done it before, and only being gentle going through 220, 400, 600, 800, 1200 and 1500 grit paper as the frets aren't actually that bad when checked with a rocker, just a few high spots here and there. I also realised that as I'm lacquering the neck, I'll need to sand down the frets anyway, so didn't do too much this time around and will do some close up shots of the frets once finished.
    Next job, sort out wiring. As expected, comes with tiny little pots, but the wiring and soldering was very neat and sturdy. Far better than my efforts are going to result in. Still finishing this off now, so will post my very messy results later.
    Next up this weekend - finish wiring, cut headstock shape, start lacquering neck.
  • I'm not a bass expert, I only have 1 for bass tracks etc, that I play like a guitar player, but isn't that an odd position for the bass pickup? Not at the neck nor at the bridge, but in the middle? Don't get me wrong, I like it, I just never saw one there before. Kinda cool. Personnally I like the HB headstocks. I was gonna reshape mine on the Tele, but fell in love with it!
    edited March 2015
    It's actually a very good position for the pickup, as it puts it in the sweet spot for a good mix of low end punch and but without the muddiness you can get from neck pickups, and high end clarity. They split the pickup in 57/58 to the standard P bass pup because of the hum the 51 single coil style pickup used to create.
    I agree, as far as a fender style headstock goes, the HB headstocks are actually pretty good. With this one I wanted to get a 51 style look as much as possible.
    Managed to get the headstock done this weekend. Here it is for prep -
    And finished! As you can see, the 51 template just about fitted in, so just needed a tiny bit of sanding to smooth it out, and now it's ready for spraying this week.
    Soldering iron managed to die just when I needed it, so another ordered and wiring to be finished this week. I also went to cut the pickguard from the white pearloid sheet I had, and realised that the pickguard sheet was guitar sized, so not big enough. Annoyingly this means I'll have to leave this and save it for another time.
    edited March 2015
    Lacquering the neck has been an experience. A truly awful experience. It would appear that you need one thing, of which I am lacking.
    Patience.
    I'll get some pics up soon, but in the process of trying to even out the back of the neck with fine steel wool, it has dried with uneven depth patches. I was concerned about the fretboard and front, but this has actually not come up too badly. However, the back, thanks to some heavy handedness from me, is patchy and I'm going to need to be refinished at another time. As I need the bass next week, it'll be in a few months.
    The whole point of doing it was as a learning experience, which is what it's been. I've stained and lacquered before, just not a tint lacquer. Couple of points I've learned is - 1. resting guitar neck horizontally, rather than hanging vertically, is much better for an even finish 2.Take time with spraying and do a single spray, and give it several hours between coats, and 3. never touch drying finish, even if you think you can wipe out a drip blob. The consequences are horrendous.
    Anyway, more pics up soon. Maybe not of the back of the neck, due to the embarrassing mess.
    edited March 2015
    The front. Pretty happy with this so far, given the difficulty of spraying over frets, first time and so on...
    Headstock close-up. Everything looking good so far...
    And then THE HORROR. THE HORROR...
    That, my friends, is what blind panic over the course of several evenings looks like. As you can see, it's also fair bit darker than the rest, as for some reason in my panic about how much tint spray I had left and being left with a thin tint, i decided to empty the entire remaining contents of the spray onto the neck. Maybe if people ask, I can just say it's "figuring in the wood" or summat.
    Another view of the problems here -
    Be kind peeps, be kind.
    Well, the front looks great and who the hell sees the back anyway! Actually doesn't look too bad and easy enough to re do once you have a gap in playing commitments...
  • PVO_DavePVO_Dave Frets: 2373
    Or, give the back of the neck that worn in look / feel with wire wool, which should remove some of the colour too?
    Thanks Andy. That was a consideration Dave, and I may go down that route later. I should have just sanded back and restarted the back of the neck when the patch came off, but wasn't sure how much I had left in the can. Turned out I had plenty.
    All a learning experience anyway.
    Nearly finished, just some sealer clear coats to do, then re-build and ready to play.
    edited March 2015
    I'm also now going to take the body down to a satin/matt finish, just to give it a more vintage look without going for full relicing.
    Quick question on clear coating and final sanding on the neck if anyone can help.
    My current plan is to do around 6-8 coats of clear nitro coat, then wet sand 1000 grit, 1200 grit and 1500 grit in around 1 week's time, once the clear coat nitro has cured.
    Will this leave a relatively glossy finish? Could I do any sooner than 1 week?
    edited March 2015
    Aaaand it's done.
    So from the standard bass, I've -
    • Changed Bridge to Wilkinson brass saddle bridge
    • Changed electronics to 250k CTS pots and orange cap
    • fret levelled
    • Cut headstock to standard tele bass shape
    • nitro vintage tint and clear gloss coat
    • sanded and polished body and pickguard to give a semi-gloss/satin look
    • fitted standard P bass bridge cover
    Other jobs for the future will be to change the wilkinson pickup for a seymour duncan single coil, but it's fine for now, and to cut and fit a white pearloid pickguard, when I can be bothered.
    All minor changes really, but lacquering the neck was a learning process so glad I had a go at it.
  • RockerRocker Frets: 4978
    Better than impressive my friend.  Great work.  Well done.  Enjoy.
    Nil Satis Nisi Optimum
    Lovely job - well done!
  • Nice looking bass. Neat work mate.
    Thanks all. Happy with the way it's turned out generally. The neck tinting isn't good enough, but a good learning experience and still left with a very playable bass at the end of it all.
  • Hi 5redlights, I have the same bass as you, Mint aren't they?
    One of the first things I did was change the cheap looking silver screws on the pick guard.
    I used black screws and the difference was amazing for less than a £. Them I took off the useless thumb rest
    and placed two black shorter screws in the remaining holes.
    Who can play using them anyway ? shouldn't they be above the strings? HaHa! I bet that will open a can of worms!
    Next I changed the Bridge for a vintage fender style. Less mass but much better tone and growls.
    I was going to re-shape the head like you have, but only because my puppy chewed the end of the headstock.
    Silver knobs replaced for black ones, again looks more quality now
  • paulnb57paulnb57 Frets: 3053
    Isn't it a finger rest, so you can play with your thumb, like wot Sting does?
    Paul
  • stimpsonslostsonstimpsonslostson Frets: 5418
    edited August 2015
    So, you'e had the bass for a wee while now. Fancy giving an update/review of it?
    I'm in the market for a CHEAP p-bass type thing and am strongly tempted by this- I enjoyed modding my HB Te52 into an Esquire, and quite fancy another wee modding challenge. I'm impressed with your work and would plan to do almost exactly the same! (with the possible addition of a Mojo pickup if needed.
    Would you recommend it?
    I used it for several weeks in a work covers band playing a variety of song styles and it did a good job, if a bit basic. The sound is slightly less characterful than a split coil style P bass, but has that slight vintage woodiness that you'd want from a 50's style single coil. The neck is very nice and playable, and overall the bass feels sturdy. The standard tuners are actually OK and hold tune well; I was expecting them to need changing but they've been fine. I also don't see much point in changing the pickup; it's actually quite good and the sound quality is fine. I'm sure I'll change it at some point, but for now it's going to stay.
    It's not getting used much at the moment as I'm playing something else in preparation for modding it (so wanted to give it a couple of weeks to find out the weak spots), but the next step is to put some flatwounds on it to add to the vintage feel, and use it for motown/60's rock songs. It'll probably be back into circulation in the next couple of months.
    I'm predominantly a bass player, and wouldn't advise on having this as a main bass (a PJ type bass would be a much better option in that scenario if you're only looking at 1 bass) but if you're looking for something a bit different to have a play with, it's a nice choice.
    edited August 2015
    Cheers. Duly noted.
    I'm a former bassist who's moved to the dark side & am missing playing bass.
    I'm torn between the coolness & uniqueness of this and the practicality and familiarity of a standard P-bass clone (PB20 being a front runner).
    How's the neck? Is it good and chunky as a P-bass should be?
