Real Gibson or Chinese replica ~ ~ ~ how do you tell ???
There seem to be a lot of Chibsons out there, mostly sold as replicas, but how do you tell if an unscrupulous seller wants to palm off a Chibson as the real thing.
What are the differences, what are the give-aways, what to look for, and how do you stop yourself getting burned?
«134
  • ICBMICBM Frets: 72311
    edited December 2013
    I'm working on one at the moment… I'll see if I can take some pics.
    I'm normally very wary about this sort of stuff - I don't approve of them and don't want to get 'tainted by association' if it should ever get sold on by someone less scrupulous, so (with full approval of the owner - there's a story behind this one which makes it less dodgy than normal, which I won't bore you with) I have burned "Made In China" into the floor of the bridge pickup cavity :) .
    Suffice to say for now, it wouldn't fool anyone who has held the real thing, but it's good enough to possibly fool someone who has only seen pictures and not known what to look for. Scary. I know what it cost on sale in China too, and that's even more scary :-O .
  • DougDoug Frets: 172
    There are many obvious differences to someone familiar with Gibson USA atm, BUT they are getting better!, the one that sticks out to me is they always use the large metric bridge posts ~same as fitted to Epiphone. Just be aware if you are buying new, that the Chinese often use photo's of genuine USA Gibsons in their ads.
  • Nibs is one, though some 2014 Gibson models won't have them either apparently...?
    And this fake I have here does… so watch out!
    Count that as one that is no longer useful, I'm afraid.
    They're getting good!
    Speaking impartially, is the chibson you're working on a good guitar? Say, if it had Ltd, epiphone etc on the headstock, would you believe it?
    Nice working on stamping it with its birthplace, too.
    It's not a bad guitar. It had a couple of playability issues - ridiculously high nut, very sharp fingerboard edges and nibs - but is actually pretty good now it's fixed. It sounds OK - it has a nice bright jangly ring to it, but it doesn't have the power and thickness of a real Gibson. It's also too light, in my opinion - 7lbs 3.5oz - and it's not just that I don't like light overly-light Gibsons either (although I don't), it just feels insubstantial. You can feel the hardness in the finish, which is very un-Gibson-like, and the two things together along with the too-sharp radii at the edges give it an odd "eggshell" feel. You'd only know this if you'd played a real one though.
    Would I think it was OK if it said Epiphone on it? Yes, because it is an Epiphone! Made in the same factory, almost certainly - the pickups are stamped Epiphone on the bottom. Naughty naughty… although I'd be astonished if Gibson don't know this is going on.
    Photos to follow.
    edited April 2016
    This is after the work I did - before this thread came up unfortunately. I've changed the pickups - the originals are chrome-covered - and dressed away the edges of the fingerboard including bevelling the nibs, which were 'square' before.
    First impression:
    Pretty good! Although there are two clues already: the cutaway horn shape is wrong, too 'soft' or rounded; and the knob layout - it's a parallelogram with the treble tone knob too close to the edge of the guitar, on real Gibsons it's an asymetrical layout. (The pickguard didn't come with it so I don't know what it's like.)
    Closer view:
    Headstock:
    I left the truss rod cover off because it's so appalling it wouldn't fool anyone and made it look too obviously fake - but it is a correct 2-screw type so it would be easy to replace with a proper one. The Gibson logo is a bit more 'pearly' than it looks in this pic but not as much as a real one. Notice the 'sunken' Allen key truss rod instead of the correct external nut type.
    Back:
    Again not bad, but the incorrect symetrical control cover, and the matt textured plastic of both covers are pretty obvious. Also the body edges are too sharp and 'crisp' compared to a real one which are slightly more radiused. Oddly enough the cutaway horn doesn't look so bad from behind.
    Closer view:
    Headstock back:
    Very naughty 'Made In USA' stamp - but both it and the serial number are impressed into the finish, instead of into the wood and then finished over. The font is also too large. The machineheads aren't far off but the keys are too 'soft' edged and very slightly too green.
    Bridge and tailpiece:
    Clearly wrong - the bridge has screw slots in the tops of the oversized posts and no knurled height-wheels, the tailpiece is much too square-edged, and the tailpiece studs are proud of the body instead of being sunken into it. (I've flipped the lower three bridge saddles round - as stock they faced backwards; Gibson only reverse the A and E at most.)
    Nut and truss rod:
    Notice the nut has moulded grooves (soft edges at the tops) instead of being cut from blank; it's also too white and too sloping on the headstock side. The wrong truss rod adjustment is clear. Interestingly it's a double-acting rod and works well, which is important since the neck has a back-bow otherwise!
    Switch close-up:
    A lot of useful detail here. First, notice that it *does* have fret nibs. But the binding is too narrow over the body, and doesn't go down to the top as it should. The switch ring is wrong - although I've improved this one (the original was even worse! and had an extra washer under it) it's a slightly too tall flat knurled nut, instead of being a collar with an internal bevel which goes down slightly into the body. The strap button is also wrong - it should be a small, flared aluminium one (which is actually pretty useless at holding a strap, these are better!) rather than a chunky chromed one… although these are easy to change.
    I don't have a real Gibson here to post the equivalent pics, but hopefully these and the descriptions of why the various bits are wrong should help. But remember that it's only a matter of time before they start getting more of these details right - some people think it's even a bad idea to post stuff like this in case it gives the makers a hint, but in reality they already know - they aren't fools, it's just not economically necessary to get them 'righter' yet.
  • Thanks for the replies guys.  Just like ThePrettyDamned said, I also thought the nibs were one give away.
    Fantastic post ICBM, thanks for the detailed descriptive text, and the photographs make excellent reference, good job.
    Thanks so much for putting this together, a great resource for us all.
    It really is frighteningly close to the real thing.  Thankfully obvious stuff like Korean / Chinese style bridge & posts, white infilled serial number, and a number of "wrong" fittings and appointments make it stand out.  The truss rod adjuster will probably be a future give-away too.  Some of it is very subtle though.
  • Great post ICBM. The bridge posts with the screw slot is a giveaway as has been said, I think the black writing on the poker chip is a simple mistake as well. The headstock looks too narrow (or not flared enough at the top) to me.
    I'm intrigued about a couple of things that don't quite add up if it's basically an Epi that's been made to look like a Gibson - nitro or glass-like poly? No scarf joint at the headstock, but is the back a veneer over a block body?
    There's some details there that are wrong that I think are "right" on my Epi, which makes me suspect the theory that these come out of the Epi factory when nobody is looking - they'd get the horn/cutaway and knob arrangement right, surely? Sourcing their bridges and pickups from the Epi supplier maybe.
    Good lord! I didn't even spot that and I've had it in front of me most of the afternoon. It's *incredibly* well done - you can't even see it easily even if you look closely at it round the edges. It is, though - there's a join visible in the end of the guitar (just a two-piece, but it's there) which is not in the veneer.
    Polyester finish, yes. That's one of the things that makes it obvious it's not real if you hold it - it's too hard and glassy. The headstock is just too narrow, although it's very close. No scarf joint.
    I agree it could just be the pickups that are Epiphone - they will be though, since there would be no benefit (quite the opposite) in faking them on a guitar which is supposedly a Gibson.
  • p90foolp90fool Frets: 31583
    Nice one ICBM.
    Another common mistake they make is the "Les Paul model" transfer font is wrong, the thickness of the line is too constant.
    It always strikes me as an odd mistake, given how easy it would be to get right compared to say, fret nibs.
  • NeilNeil Frets: 3621
    Good educational post.
    TBH the differences if you have owned a real one would stand out like a sore thumb especially the poly finish but for somebody unaware..........
  • stickyfiddlestickyfiddle Frets: 26970
    Great stuff from @ICBM. Really good to get properly analytical pictures of all of that. Between this fake with nibs and new Gibsons without them it's going to get really hard to tell someone just a couple of points to look out for. Even the strap buttons on the 2014 Gibsons are more like these ones! The bridge posts are the next most obvious thing that the fakers will probably fix next.
    The rest is more of a feel thing. It's all the tiny details; the exact shape of the headstock, the positioning of the knobs, the fricking font on the logo, the feel of the finish and colour of the binding, the shape of edges of the pickup covers. Noobs aren't going to be able to pick up on all that.
  • RockerRocker Frets: 4980
    Seriously good stuff from @ICBM, many thanks for the post detail.  TBH I am not sure I would be able to spot a fake [the poly finish or the truss rod cover aside] from the real thing.  And I had a real Gibson LP Custom from 1978 to about 1985 [I had given up guitar at that stage].  The guitar pictured, used by ICBM to explain what to look for, looks like a pretty decent Gibson guitar.  If it plays OK, stays in tune and sounds good then it might be a good buy.  The obvious problem is that if it is sold on as a Gibson......
    Nil Satis Nisi Optimum
  • mike_lmike_l Frets: 5700
    One's got shoddy workmanship, no attention to detail and poor quality control.
    The other's made in China.
    =P~
  • Great post. The headstock is far too straight and narrow... almost Melody Maker shaped.
    Many of the chambered Les Pauls only weight around that. The one I picked up was just a shade over 7Ibs, and a friends 2007 Standard weighs just under 7Ibs.
    If the Chinese go that last mile and get all the details right including a much larger range of serial numbers its going to cause paranoia when buying any Gibson.
  • If all the details are right then there's no difference so who cares?  ;)
    My bank balance lol
    The £1500 I saved could have been spent on a new blow up doll
      =P~
    Oh Ho Ho!
    Oh!
    Oh... You're right. Have a LOL.
