Yamaha Silent Guitar... Anyone Played One ?
I know @BintyTwanger77 has just got one...
They look superb and the demos seem excellent.
Anyone got any thoughts ?
  • Silent Guitar?!?!?!?
    Easy... take 1 x normal guitar... cut all of its strings...
  • Yes - all of mine were silent when I was married...
  • JalapenoJalapeno Frets: 6393
    They're good !  Seen Brian May use them with Queen.
    I had to reduce the bridge height a bit for playability (Easy-peasy - whip it out, sand it a bit on the flat, put it back, try it)
    Feedback
  • Very nice.  I had the last version, the newer ones have some kind of body modelling so that it's not just UST to e.  But even so mine was very nice(the lower nylon model).  As with all Yamaha's, expect to need ti give the frets a buff prior to use.
  • BintyTwanger77BintyTwanger77 Frets: 2232
    edited December 2017
    Yep, got the nylon string version on Saturday.
    I have just finished playing mine over headphones for about an hour and a half, forgot what time it was... holy shitsnacks. This thing is addictive, it has me playing like I haven't played before. It sounds brilliant on headphones and through an amp, the technology involved is wizardry. Blown away. I would love to try the steel string as well.
  • prowlaprowla Frets: 4928
    https://uk.yamaha.com/en/products/musical_instruments/guitars_basses/silent_guitar/index.html
    Perfect for playing your favourite hits:
    • Hush
    • Silence is Golden
    • The Sounds Of Silence
    • Silent Night
  • Guitar_SlingerGuitar_Slinger Frets: 1489
    I've seen Hamish Stuart play twice - the first was with a 60s Tele that is probably second to Nile Rodgers' Strat in the list of records it's been played on. The second time was with a Yamaha silent guitar, at a gig. IIRC it was about 12 years ago, during a guitar show in Wembley Conference Centre. There was him and an hour later, the Hamster.
  • KebabkidKebabkid Frets: 3311
    I've tried both the nylon and steel string on quite a few occasions in shops and have been on the look out for a steel string one at a good price.
    The plugged in sound with the built-in reverb through either an amp/PA or headphones is very good and handy and so it can be used as a live or recording guitar as we know but as you can unscrew and take off one of the body arms, it can also make for a handy travel guitar, although there's hardly an acoustic sound there, but nice to have when you go away.
    I seem to remember there were 2 neck widths for the nylon.
    The adaptor/power supply can be a but cumbersome and the chorus seemed a little over-cooked but a useful thing.
  • I ended up selling mine and got a an Alhambra electro acoustic, but that guitar is not quite as playable, but to be fair the Alhambra has a firmly classical action and no truss rod to bring it down.  That's how classical should be played but I must admit, I miss the slick playability of the Yamaha for non classical styles
    The few minor issues of the previous generation seem to have been addressed, so I would have another. Obviously, great for travelling as well.....
  • DiscoStuDiscoStu Frets: 5517
    I've fancied the nylon one for a few years now. Just watched the Guitarist review vid and I still fancy one!
    Questions: Can you have chorus and reverb at the same time? Do the effects have level controls or are they just fully on or off?
    No, the reverbs and chorus are on the one knob, like the effects controls on a Roland Cube amp.
  • I used have one years ago.Their ok if you can put up with the narrow nut,it’s more like a electric neck.I couldn’t.
  • dindudedindude Frets: 8537
    I quite fancy the steel string for silent headphone practice - never found a headphone solution for electric that is inspiring so maybe going left-field is the way...
    An interesting 2015 vid from Mick and Dan on using effects with acoustics and Dan uses a Silent Guitar - it's versatile, in a hybrid sort of way, too when using overdrive.
    Only negative is that Reverb/Chorus eats batteries, you'd need new batteries for every gig.
    Feedback
  • xDottorexDottore Frets: 274
    I’ve the steel string. Love it but then I find that I’m a bit of a Yamaha fanboy.
    You need an idea of what you are going to do, but it should be a vague idea.
    My feedback page: http://www.thefretboard.co.uk/discussion/91654/
  • Appreciate the input folks...
    Im gonna try one tomorrow :)
    Waz - see if you can try it plugged in as well into an acoustic amp or PA rather than just headphones.
    Let us know how you get on :)
  • Cos,
    Will do - I plan to try some amps too...
    Mind you, knowing me, Ill walk out with a 1937 Martin or summat daft... :)
    Waz
  • AlnicoAlnico Frets: 4616
    If you know what you're talking about, can I ask a serious question I haven't really looked at in 30 years?
    I started, like many at the age of 8 playing the 'School guitar' at school because The devil's sister my mother wouldn't let me take the dreadnought that my Dad had given me and to be fair, to a certain point I could see why.
    My point is that I spent most of my time playing and more or less enjoying the nylon string guitars at junior school but I just couldn't get past that action height. I couldn't understand and still to this day have no better idea, despite having watched and listened to a lot more than I had done in 1980, why you would want that and how in any mechanical way it could be of any advantage to playing.
    Genuinely I just can't see it, why?
    Your fingers are moving faster than I can think so why do you want it to take longer for each finger to press, fret and release each string? It makes no sense to me at all?
    Between the age of 8 and 12, I did try and developed enough loose fingerpicking skills for it to be an advantage as I picked up steel string acoustics and electrics.
    I challenged it at high school and was told to "Piss off then if you don't like it !" and that's more or less what I did.
    Thing is I like classical music, really like the feel and the sound of nylon strings and I guess the feel of them too but this has always stopped me dead in my tracks.
